Trouble getting Loctite 515 https://ausmini.com/forums/viewtopic.php?f=5&t=75427 |
Author: | miniDave [ Fri Feb 10, 2012 7:29 pm ] |
Post subject: | Trouble getting Loctite 515 |
Been on the run around today trying to find some Loctite 515 for the gearbox to block gasket (as suggested). Can only find a 50 ml tube of 518 for $42. ![]() So what is the finite difference between 510, 515 and 518? Cheers - |
Author: | justminis [ Fri Feb 10, 2012 8:03 pm ] |
Dunno what 510 is (or the finite difference), but you can use 518 as you would 515! |
Author: | drmini in aust [ Fri Feb 10, 2012 8:28 pm ] |
http://au.iloctite.com/en/loctite-574-5 ... -gasketing Any would do. ![]() yeah I use 518 if I can't get 515. But I have a whole cartridge full of 515.. ![]() ![]() |
Author: | miniDave [ Tue Feb 14, 2012 5:44 pm ] |
Got a 50ml tube of 515 off the racks at Blackwoods. $24.95 including GST. Hopefully 50 ml will do what is required for one engine? |
Author: | drmini in aust [ Tue Feb 14, 2012 6:13 pm ] |
Should do a couple of engines Dave. ![]() Put it on thin- you only need a smear. |
