It is currently Fri Jun 27, 2025 5:48 pm
 Post subject: Spring seat cutter
PostPosted: Mon Jan 23, 2012 11:03 pm
Folks
I am building a head for a race mini and I need to lower spring seats to suit new springs, does anyone know were i can buy a valve spring seat cutter from. I have searched the web but can't find anything that is the right size.
Any help would be appreciated
Ta Mal
PostPosted: Tue Jan 24, 2012 6:14 pm
I know what you have in mind, the flat cutter works similar to a tap reseater but is mounted on a pilot. Not seen one for years.
It is possible to make a HSS single point tool to put in a bench drill, but IMO would be easier to take the head to a machine shop and let them spotface the spring seats in a milling machine. :wink:
PostPosted: Tue Jan 24, 2012 7:49 pm
Cranecams Mal :)
They don't keep them at their local agents but you can order direct from the states
PostPosted: Wed Jan 25, 2012 1:36 pm
Do you know what the crane cams part number is, can't find anything the right size in their online catalogue.
M :shock:
