crankshaft pulley explosion https://ausmini.com/forums/viewtopic.php?f=5&t=74697 |
Author: | redrocketrider [ Tue Dec 20, 2011 7:44 pm ] |
Post subject: | crankshaft pulley explosion |
hey guys, bit of an issue my crankshaft pulley has busted into about 4 pieces. im stuck with the inner part of it left. does anyone know how I can remove it? the nut is undone, but i sat it there so as not to loose it ![]() ![]() |
Author: | michaelb [ Tue Dec 20, 2011 7:59 pm ] |
You could try and carefully lever it off but be carefully not to damage the timing cover Alternatively try a pulley remover, but not sure you have the space for this to fit? |
Author: | drmini in aust [ Tue Dec 20, 2011 8:12 pm ] |
A 2 leg puller will work if you put a jack under the motor, then remove the engine mount & its bracket. |
Author: | michaelb [ Tue Dec 20, 2011 8:41 pm ] |
I just noticed! That looks like an easy way to get to the speedo cable, but I guess that is not what you were thinking ![]() |
Author: | kiwiinwgtn [ Wed Dec 21, 2011 6:29 pm ] |
did it just fly to bits or was it damaged trying to grt it of fthe crank shaft |
Author: | redrocketrider [ Tue Dec 27, 2011 3:35 pm ] |
smashed to bits while driving. |
Author: | mini7boy [ Thu Jan 26, 2012 1:30 am ] |
Hello, would you mind disclosing the brand name of the pulley/damper that failed? Thanks. |
Author: | miniDave [ Thu Jan 26, 2012 6:40 am ] |
mini7boy wrote: Hello,
would you mind disclosing the brand name of the pulley/damper that failed? Thanks. Looks to be the standard pressed tin type used on 998s. Very easy to damage trying to get off. I had something similar when rebuilt to a 1185 but went to the 1275 type dampner. |
Author: | dodge [ Thu Jan 26, 2012 8:08 am ] |
undo the bolt and warm the hub up with a oxy, then give it a tap to loosen it |
Author: | drmini in aust [ Thu Jan 26, 2012 2:59 pm ] |
It should be just a slide on fit, 2 screwdrivers will get that off. You won't do it any more damage... ![]() |
