Fitting bottom arm bushes https://ausmini.com/forums/viewtopic.php?f=5&t=74525 |
Author: | coopar [ Wed Dec 07, 2011 3:04 pm ] |
Post subject: | Fitting bottom arm bushes |
Do brand new bottom arm bushes need to be pressed onto the pin? The inner sleeve seems too small for the pin. I dont want to go hacking the pin or sleeve unnecessarily. Im going to try warm water but i'm thinking that wont do much for the metal sleeve?? |
Author: | sgc [ Wed Dec 07, 2011 3:22 pm ] |
Are you sure you've got the sleeve from the old bushes off the pin? They do like to fuse themselves on pretty good... |
Author: | TheMiniMan [ Wed Dec 07, 2011 3:38 pm ] |
i generally wire-buff the old pins (once the old sleeves have been removed) & add a little copper coat before fitting |
Author: | simon k [ Wed Dec 07, 2011 5:13 pm ] |
a G clamp will come in handy when you're putting it back together too |
Author: | coopar [ Wed Dec 07, 2011 6:54 pm ] |
Must be old sleeves. Wouldve guessed it! Cheers guys |
Author: | GT mowog [ Thu Dec 08, 2011 5:19 am ] |
Have you got the right bushes? Early cars up to about 66 or 67 used a bush without sleaves. The arm itself is different. |
Author: | coopar [ Thu Dec 08, 2011 5:35 am ] |
Got a 69, my bush set is the one suited to adjustable suspension. |
