It is currently Fri Jun 27, 2025 10:46 am
PostPosted: Wed Dec 07, 2011 3:04 pm
Do brand new bottom arm bushes need to be pressed onto the pin?
The inner sleeve seems too small for the pin.
I dont want to go hacking the pin or sleeve unnecessarily.
Im going to try warm water but i'm thinking that wont do much for the metal sleeve??
PostPosted: Wed Dec 07, 2011 3:22 pm
This space for rent
Are you sure you've got the sleeve from the old bushes off the pin? They do like to fuse themselves on pretty good...
PostPosted: Wed Dec 07, 2011 3:38 pm
i generally wire-buff the old pins (once the old sleeves have been removed)
& add a little copper coat before fitting
PostPosted: Wed Dec 07, 2011 5:13 pm
a G clamp will come in handy when you're putting it back together too
PostPosted: Wed Dec 07, 2011 6:54 pm
Must be old sleeves.
Wouldve guessed it!
Cheers guys
PostPosted: Thu Dec 08, 2011 5:19 am
Have you got the right bushes? Early cars up to about 66 or 67 used a bush without sleaves. The arm itself is different.
PostPosted: Thu Dec 08, 2011 5:35 am
Got a 69, my bush set is the one suited to adjustable suspension.
