https://ausmini.com/forums/
dizzy movement
https://ausmini.com/forums/viewtopic.php?f=5&t=73340
Author:  purpleminik [ Sat Oct 01, 2011 1:35 pm ]
Post subject:  dizzy movement
hello my name is jamie i am fairly new to working on my new mini, my question is ,my mini when you grab the dizzy it moves about 15mm each way and about 10mm in and out is this a common fault ?? is there a qick fix?? your advice would be much appreciated
Author:  kirby [ Sat Oct 01, 2011 2:18 pm ]
Tighten the hold down clamp :D
Author:  d1ck0 [ Sat Oct 01, 2011 5:08 pm ]
Post subject:  Re: dizzy movement
Are you talking about the whole distributor, or if you try and move the rotor button inside?
Dicko.
Author:  purpleminik [ Sun Oct 02, 2011 9:31 pm ]
whole dizzy
Author:  d1ck0 [ Mon Oct 03, 2011 8:45 am ]
purpleminik wrote:
whole dizzy
See post 2 above ^^
The clamp will tighten around the Distributor and bolt to the block.
Dicko
Author:  drmini in aust [ Mon Oct 03, 2011 3:19 pm ]
In some cases due to previous overtightening, the dizzy's alloy shoulder inside the clamp breaks. Then the clamp doesn't work.
This applies to early dizzys that are hollow inside there, later ones (45D etc) are solid.
There are a few ways to fix this, there was a thread here recently.
I fixed a Cooper S one recently by machining the shoulder down and shrinking an alloy ring onto it.
Author:  Convertible Mini [ Thu Oct 13, 2011 9:44 am ]
Post subject:  Dizzy
Reading the above.... The solution would be to buy a new Dizzy from me and might be an idea to go the modern way.... electronic.....
