1505 crank into A+ engine. will it fit ? https://ausmini.com/forums/viewtopic.php?f=5&t=71372 |
Author: | justfanginaround [ Sun Jun 19, 2011 7:19 pm ] |
Post subject: | 1505 crank into A+ engine. will it fit ? |
Will a 1100s crank fit into a 1275 A+ block ? Do I need anything special to do it ? Cheers Jon |
Author: | drmini in aust [ Sun Jun 19, 2011 7:25 pm ] |
Sure it will fit in as stroke is under 86mm, and if it's a stroker the S conrods will fit too- although there is a little less room in there than in the A series 1275 block. |
Author: | adamstuart [ Sun Jun 19, 2011 7:27 pm ] |
Just a quick question, since things seem to be answered: Why are you putting an 1100 crank into a big bore? Don't have access to a 1275 crank I presume? |
Author: | drmini in aust [ Sun Jun 19, 2011 7:27 pm ] |
1100S crank IS a big bore one. They are 1275cc. The 12G1505 has bigger crankpins so it can be stroked 3mm like in my 1412. |
Author: | 1098 [ Sun Jun 19, 2011 7:28 pm ] |
1100S, Adam... It's a Morris 1100'S' engine |
Author: | justfanginaround [ Sun Jun 19, 2011 7:37 pm ] |
thanks for the quick reply. 73.5mm bore X 85.00mm stroke = 1443cc. should be fun in the back of the FANG. |
Author: | adamstuart [ Sun Jun 19, 2011 8:01 pm ] |
Ahh. The 's' Was lower case, so I missed it! Going blind in my old age, don't mind me. I swear that clubman was brown too.. |
Author: | CARTER_GT [ Mon Jun 20, 2011 5:26 pm ] |
justfanginaround wrote: thanks for the quick reply.
73.5mm bore X 85.00mm stroke = 1443cc. should be fun in the back of the FANG. NO,NO,NO,NO,NO you need to put it in the LS so next time im around i can look at it. |
