It is currently Sun Jun 29, 2025 3:06 am
 Post subject: Wider Flares Needed!
PostPosted: Tue May 10, 2005 12:02 pm
I've just had four new A008 165/70 x 10 fitted to my 5" contessas (wide offset - not LS) on my van. Looks fantastic and handles great, but I'm sure Mr Plod will not be impressed....
I'm running S spacer drums all round and I have the late model black plastic flares. Now I have the entire sidewall and a few mm of tread hanging out of every guard!
I need wider flares. Is there something out there that will cover the slightly wider rubber and fit using the holes from the existing flares or cover them up?
There must be tons of guys running the same wheels, brake widths and tyre size - what flares do you use?
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue May 10, 2005 3:35 pm
my wife is running 10x6 inch wheels on her mini with yoko A008's. I have just put the cheap inocenti type flares you get from karcraft for $60. This pic shows there inside the gaurds nicely, with spacered drums alround.
1974 Moke - 998cc
PostPosted: Tue May 10, 2005 5:10 pm
The innocenti (or late Mini) type flares is what I already have.
The Contessas I have must have a more positive offset or deeper dish than your wife's wheels. :(
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue May 10, 2005 7:35 pm
Brett,
I'm running Yoko A008s on your wheels with Inno flares, they are legal up here. No worse than a Mk1 S with 4.5 steels & no flares..
:idea: Lower it a bit- then the tops of the fronts will kick in... :wink:
PostPosted: Thu May 12, 2005 10:02 am
Mr Plod won't care Brett, count the number of cars like that at the next vic mini run... they all do it - they do get upset when you drive around with no flares at all through, even if you only took them off to paint them the night before :evil:
PostPosted: Thu May 12, 2005 11:24 am
I am with you Bnicho, same prob, sidewall and few mills of tread. I have little problem when tooling around town, but I will have to take it over the RTA pits (not just local garage) coz of the conversion and I know they're going to give me grief... :evil:
PostPosted: Thu May 12, 2005 1:31 pm
Anybody say negative camber?? That will fix it 8)
PostPosted: Thu May 12, 2005 1:51 pm
:lol: :lol: :lol:
PostPosted: Thu May 12, 2005 5:38 pm
Yeah, I like that idea. I'd rather spend $$ on adjustable bottom arms and trailing arm brackets than a set of flares. :lol:
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Fri May 13, 2005 1:52 pm
Mine are the same they sit out side the flares like that with the inno flares on I have put on 12x5 and 13x5.5 and they all sat the same.
I have been pulled up and nothing was said about them.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
