It is currently Fri Jun 27, 2025 12:26 am
PostPosted: Mon Jun 13, 2011 10:55 pm
Now i think I've thought of everything however Im sure i haven't. Basically i plan on taking out the A+ and putting in the A. I'm leaving the luxury world of air-con and heaters behind and just doing a straight froward swap. The obvious problems I've thought of are:
1. Top passenger side engine stay
2. I plan on changing the pot joints to the H/S ones i have. (will this incur a change in drive shafts?)
3. Will the booster hit the clutch arm?
In addition to the above uncertainties, the other problems I've neglected to think of are: .......
thanks,
Bill
PostPosted: Mon Jun 13, 2011 10:57 pm
1. It's optional if you're putting in a remote change gearbox, but not a bad idea anyway
2. yep, change the driveshafts
3. no
PostPosted: Mon Jun 13, 2011 11:20 pm
this is good news, any other unsuspecting problems anyone can think of I'm going to run into.
Bill
PostPosted: Tue Jun 14, 2011 12:30 am
When I put an A+ in my car the engine mounts supplied with the motor would not line up with the subframe. I just used the mounts off the old A series engine in the end.
2008 Prado GXL
PostPosted: Tue Jun 14, 2011 12:36 pm
I put a '71 1100 van engine into my 88 rover.
Used the rover driveshafts and pot joints, and fitted a passenger side engine steady from a moke so the heater hoses could still go through.
Late rovers don't have a passenger side engine steady, they only have two on the drivers side. I have three in my deluxe, the normal one on the firewall and two running from the gearbox to the subframe. Engine is solid as a rock and I suggest that over a second firewall mount.
I didn't have any problems with anything, but the car did have to retain the charcoal canister, and whatever other emissions gear that applied to the cars buid year.
PostPosted: Tue Jun 14, 2011 12:54 pm
ahhh k, are these the gearbox kits ive seen that mount off the sides of the diff housing on each side? i guess this would be the easier option.
PostPosted: Wed Jun 15, 2011 8:43 am
Another thing to consider is the fact that your current inlet manifold means the weber will be sticking through your aircon vents
PostPosted: Wed Jun 15, 2011 9:36 am
Yeah, ill be making a box for that. Or just stick it though in to the cabin for tweak while you drive ability.
Users browsing this forum: No registered users and 20 guests
