miniobsessed wrote:
Firstly, if this is for a daily driver USE THE 1100 CRANK! I really get sick of hearing how it's only as strong as a bent bit of wire and should be avoided. Get it crack tested - if it's all good get it balanced and it will run strongly to 6000rpm in every gear all day long (for a ROAD motor) and the extra power and torque over the 998 will make you smile everyday.
Using the 1100 crank you will need new pistons.
I wouldn't trust a 'Standard' bore unless it was carefully measured and inspected before use. Most of the time a standard bore these days requires a rebore due to wear (which will be uneven over the length of the bore). Best idea - measure the bore and go to the oversize required to get the bore spot on. In your case probably +20thou but measure.
There are many good cams out there and everyone has their views/opinions/preferences. Pick your cam grinder and ask them what they recommend.
Twins or single carb??? A well setup 1.5"SU on a good manifold will be more than a match for twin 1.25"SUs. But I too like the look of twin 1.25"SUs. At the end of the day - It's your car, if you want to use the twins (for this spec of engine, you're not going to really notice anything either way) USE THEM. Just make sure they are setup correctly (much easier to achieve with a single carb).
Have fun
Some very good advice there.
I would agree that the 1100 cranks are good, just not the 'ultimate'. Will last quite well if you're not looking for huge HP (or use huge HP) or insane revs.
You can also read Phat Kat's ( & others) tips and hints here
http://www.ausmini.com/forums/viewtopic.php?t=67980
On the Carb(s), again as miniobsessed says, the look of the twins is sexy, but stick with a single. You'll get very repectable results with a single 1 1/2", which is good up to about 80 flywheel HP!
