https://ausmini.com/forums/
Evil THoughts again ...... LPG....
https://ausmini.com/forums/viewtopic.php?f=5&t=6867
Page 1 of 2
Author:  kazjim [ Tue May 03, 2005 9:06 pm ]
Post subject:  Evil THoughts again ...... LPG....
ok all, its happening again....
LPG.. I'm thinking about it ....
Saw a great tank - about 15" diameter that replaced the spare-wheel well on a Ute..... got me thinking again..
The barrier to LPG on a mini was the tank and the non-sealed rear-firewall....
LPG is 110+ Octane (RON) and although it has a lwoer calorific value, it certainly has the potential to make a shedload of power......
an IMPCO Gas Carb (Think Forklift) is adequate for about 140HP and is very happy in a turbo "Blow-through" application . . . most six-cylinder converters are also more than adequate as well as being cheap as at the wreckers ....
oh, the fuel is also very cheap....
J
Author:  drmini in aust [ Tue May 03, 2005 9:09 pm ]
According to gas co's current ad in Open Road mag, LPG is 102 (RON). hardly worth it.. except it's cheaper once you've paid all the hardware off. 8)
Author:  kazjim [ Tue May 03, 2005 9:12 pm ]
Bugger.. used to be 111 back when i was buying.... ('92?)
J
Author:  Metalfab_101 [ Tue May 03, 2005 9:14 pm ]
Would EFI work rather than using a carb?
Author:  Morris 1100 [ Tue May 03, 2005 9:14 pm ]
Post subject:  Re: Evil THoughts again ...... LPG....
A lot of vans run a tank in the back without a firewall.
My work has a 2003 Toyota Hiace SBV with the tank behind the drivers seat.
Author:  kazjim [ Tue May 03, 2005 9:17 pm ]
Dave, but thats up there....
here in the "nanny state" we have to have it behind several shields of spent-uranium .......
Kev, even at 102RON its still better than 90% of petrol fuels.........
J
Author:  dansedgli [ Tue May 03, 2005 9:26 pm ]
I was thinkning about this too a while back.
How about instead of LPG use a straight propane tank from a forklift?
The only reason LPG is lower RON now is cos its become a mix between propane and butane(?) and the mixes arent consistant between servos anymore.
Straight propane is about 115-120 RON. The tanks are small too, I dont know if they are different to normal LPG tanks though. I dont see why they should be.
Author:  Harley [ Tue May 03, 2005 10:05 pm ]
Can't you just run 98 octane with additive?
(Ignore cost, are there any benefits?)
Author:  drmini in aust [ Tue May 03, 2005 10:54 pm ]
That's what he and I are running now. Great stuff, BP & Mobil's 98, anyhow.
Author:  FatMaserati [ Tue May 03, 2005 11:54 pm ]
I've always been told that LPG cost less at the pump, but costs more in engine wear...
Stick to a nice 98.
Author:  Konzo [ Wed May 04, 2005 12:33 am ]
LPG is CRAP!!!
We have it in most of our work cars (cheap ass boss) and the have alot less power then the petrol cars :(
Author:  kazjim [ Wed May 04, 2005 7:29 am ]
Lucas, i had a "little" holden V8 running on "that Crap" ....
660@flywheel from a 4.2 litre ...........
When tuned and built for gas, you can get a SHITLOAD more power ......
basically, you can run a LOT more ignition advance and much wilder cam profiles than Petrol.. due to the slower-burn speed of the Gas .....
GRA in Vic have a fantastic Gas-only carb that really makes things sparkle....
J
Author:  bnicho [ Wed May 04, 2005 8:42 am ]
There is an LPG-only Mini in the Vic Mini Club. Watto did a feature on it for Mini Magic several years ago. Uses a gas-research carby and a tank that took up most of the boot. :shock:
Author:  Harley [ Wed May 04, 2005 8:58 am ]
I remember that car, the first mini I ever went in on the road.
Gets around alright, estimated 90hp I think.
I think he's trying to sell it too.
Author:  Mini Mad [ Wed May 04, 2005 9:08 am ]
James, i have an article of a supercharged LPG mini as well somewhere...i'll try and find it
