It is currently Sat Jun 28, 2025 12:29 am
 Post subject: Pot joint question
PostPosted: Fri Apr 29, 2005 1:59 pm
G'day Everyone,
I'm going to be dropping in another motor hopefully this weekend, and this one has pot joints, and I currently have normal uni joints. I'm wondering, when changing the driveshafts to suit, do I have to change the entire shaft, or can I just change the ends over?
Anto
PostPosted: Fri Apr 29, 2005 2:21 pm
I think you have to change the whole drive shaft the uni joints had a bit where the shaft could telescope to become longer / shorter as the suspension moved the pot joints just moved inside to pot on the side of the diff so the drive shafts for pot joints are solid?
correct me if I'm wrong :oops:
Roads need more corners
PostPosted: Fri Apr 29, 2005 8:08 pm
Inner spline is totally different, and shafts are different length too.
You need the driveshaft swapped, but the CVs can stay if you knock them off the shafts.
Users browsing this forum: No registered users and 35 guests
