It is currently Sat Jun 28, 2025 12:22 am
PostPosted: Wed Apr 27, 2005 6:12 pm
Um, just wondering is it possible to put a small bore head (more specificly a 12G202) on a large bore engine :?:
Normally this would give rise to the question why would you want to that? but I am thinking of trying something out and would like to be able to try it out against a 12G940 head. :wink:
If it doesn't fit, Oh well I will just have to use it on my 1100 :D
Is there any problems such as less / more studs, or things don't line up :?:
Roads need more corners
PostPosted: Wed Apr 27, 2005 7:30 pm
Nope... it will fit on but won't work, the 1275 gasket you will need to use will not cover some of the big water holes in the head. :shock:
The general rule is use the gasket that goes with the head (on small bores) but the small bore gasket won't seal the top of the 1275 block. :cry:
PostPosted: Wed Apr 27, 2005 9:05 pm
Is it possible to make or modify gaskets to fit? or is it a big hassle and really not worth it?
How does an 1100 perform with valves about the size of a standard 12G940?
Have you guessed what I am trying out ? :P
PostPosted: Wed Apr 27, 2005 10:29 pm
I have put 1275 valves (33/29mm) in a few 1098 heads now. But I turn the exhausts down to 27mm to avoid having to notch the block.
Note these valves are longer than 1100 ones- I put a 12mm flat washer under each valve spring, and pack the rockers up 2mm.
But it just won't flow as well as a 940 head does. :wink: Easier to notch the block and use a 940, or a 1316... :P
Users browsing this forum: No registered users and 35 guests
