It is currently Fri Jun 27, 2025 1:50 pm
 Post subject: 1100/1275
PostPosted: Mon May 07, 2012 10:42 am
I have an 1100 cc motor and swell modified 12g295 head . Do I put 100 thou pistons in with a small cam , or do put a1275 cc motor in . This is for my daughter to drive . What are your thoughts on this . Thanks
PostPosted: Mon May 07, 2012 12:13 pm
I'd build the 1100 up like you said.
As you already have it (and that good 295 head) it's much cheaper than buying a 1275 first, then having to rebuild that.
