pre igniation https://ausmini.com/forums/viewtopic.php?f=5&t=6467 |
Author: | troy [ Mon Apr 18, 2005 8:34 pm ] |
Post subject: | pre igniation |
rebuilt motor and box on mini nothing done to carby keeps going some times after run the bloke that did rebuild told me that the carby needs to be rebuilt first time mini owner already been ripped in rebuild any ansers[/b] |
Author: | 13secmini [ Mon Apr 18, 2005 8:48 pm ] |
have you checked the timing?? |
Author: | Mini Mad [ Mon Apr 18, 2005 8:57 pm ] |
It's a mini thing..just live with it and put it in first and let the clutch out as you turn it off ![]() |
Author: | drmini in aust [ Mon Apr 18, 2005 9:34 pm ] |
Mini Mad wrote: It's a mini thing..just live with it and put it in first and let the clutch out as you turn it off
![]() Some later engines (Metros etc I think) had an anti-run on valve. As you shut the ign off, it let bulk air into the inlet manifold to kill its fire. So it's not a new problem. My excuse- it's running 10.7:1 on 98 octane fuel. I just let the clutch up, too.... ![]() |
Author: | TheMiniMan [ Tue Apr 19, 2005 6:58 pm ] |
you`re all nastey nastey people,,, It`s called """Running On""" Make sure you have the correct spark plugs fitted,,,not "Hot" ones set fuel mixture correctly set the idle as low as it will go, while still smooth make sure the igition timing is set correctly & maybe even back it off a degree or 2 if the compression ratio of the engine has been set too high. & make sure you run quallity premium fuel let it idle for a while before turning it off all this should help if it still """"Runs On""""" then i`d have the comp ratio lowered i just can`t stand a mini running on!!!!!!!!!!!!! |
