white smoke...help https://ausmini.com/forums/viewtopic.php?f=5&t=6447 |
Author: | lobby69 [ Mon Apr 18, 2005 10:11 am ] |
Post subject: | white smoke...help |
hey all, weve just done a head reco, cam on an morris 1098, fitted into the van, its running the 848 carb and needle as the 1100 was not servicable!, we did the head gasket as well, what does white smoke mean???....running to lean? cheers, blake ![]() |
Author: | TheMiniMan [ Mon Apr 18, 2005 11:21 am ] |
have you got s brake booster/servo fitted??? |
Author: | 68matic [ Mon Apr 18, 2005 11:25 am ] |
white smoke usually means there is water in the system, either condensed water (from over night) in the cylinders or exhaust system. when i had this coming out, it usually subsides within 15 minutes driving the car, or revving it a little (a little) usually heats things up and disperses the water. it shouldnt smell like anything else but normal car exhaust gases. another close thing to white could be oil (grey blue colour) |
Author: | Morris 1100 [ Mon Apr 18, 2005 7:05 pm ] |
White smoke is a sure sign that they have elected a new pope.... ![]() ![]() ![]() |
Author: | 13secmini [ Mon Apr 18, 2005 7:08 pm ] |
Morris 1100 wrote: White smoke is a sure sign that they have elected a new pope....
![]() ![]() ![]() HAHA ![]() ![]() could also mean your turbo seals have desintegrated, if you had one ![]() |
Author: | mooman10_0 [ Mon Apr 18, 2005 8:44 pm ] |
Did you do your valve stem seals when you did the head? I know that can cause smoke, dont know what colour? |
Author: | TheMiniMan [ Tue Apr 19, 2005 6:47 pm ] |
why i asked if he had a brake booster is because when a brake booster is rooted it can suck brake fluid into the manifold & it will burn white smoke all day ![]() |
Author: | 13secmini [ Tue Apr 19, 2005 6:50 pm ] |
brake fluid in the combustion chamber dosnt sound to good,, could be a poor mans NOS system ![]() |
Author: | Morris 1100 [ Tue Apr 19, 2005 7:08 pm ] |
OT. Another unusual thing that can cause white smoke in some cars (not minis) is the vacuum modulator on auto transmissions. Some autos have a gizmo called a vacuum modulator and when it decides to die it lets auto oil get sucked into the manifold. In the last workshop I was in we were asked by a customer to fit a replacement engine to a Mazda 929 because the motor was blowing white smoke, we fitted the new motor and started it up and it was still blowing smoke. We changed the vacuum modulator and the smoke stopped. The customer paid $1000 for an engine swap that was not needed! |
Author: | aaron [ Tue Apr 19, 2005 7:23 pm ] |
Let it run, you may have something in the fuel line like i did. If it doesnt clear after 10 mins, there is something else wrong. Keep an eye on the temp too, it'll go up real quick if it's too lean. Cheers Aaron |
Author: | simon k [ Tue Apr 19, 2005 9:50 pm ] |
it's water, the head gasket is letting wther into the cylinders.... is the engine using water? do a compression test, get one of those special thingys and pressure test the radiator, or the other special thingy that tells you if you've got exhaust gases in your water |
Author: | lobby69 [ Wed Apr 20, 2005 8:05 pm ] |
ive tracked it down to worn piston rings, yeah, we did the valve guide stem seals, (full head reco) bummer! blake ![]() (but hey, it still fly's compared to the 850!!!) |
