it`s not really an issue of """How many cores"""
it`s more about "How much """"FIN AREA"""???"
the more "FIN AREA" avaliable, the better
some can argue all they like about a 4 core or a 3 core or a 2 core being better than eachother, whatever,,,,,if one has more "FIN AREA" than the other, then that`s the better choice, 4 cores can seem to block the flow of air,,,2 cores may seem like not enough flow,,,all crud really, they all work well, just that the one with the most "FIN AREA" wins , simple!!!
& on top of all that--->i can show you a fully blocked 4 core & i`d bet the clean 2 core works better,,,or i can show you a fully blocked 2 core & the clean 4 core would be better,,,so being blocked really doesn`t help either,. but,,,if you actually sat down & took the time to work out the "FIN AREA" of each rad,,,then take the one with the most "FIN AREA"
i personally use a std old Aussie "S" 3 core in my 1510cc donk & it sits on the thermostat the whole entire time while driving, at speed or at slow,,,traffic & at races,,,hardly moves & i don`t have any extra rad core or heater matrix or diddly squat,,,just our simple by-pass hose mod from the back of the head (heater outlet) to the top tank of the rad, & we block off the old std by-pass under the head to the water pump, easy-peasy.
so,,,remember "FIN AREA", that`s where the heat is dissipated from.
have i mentioned anything about """FIN AREA""" yet?
