It is currently Fri Jun 27, 2025 1:55 pm
PostPosted: Wed Mar 30, 2005 8:12 pm
Heya fellas, ive run a brick wall; in a way of how the hell do i attach my custom dash face into the rails or whatever.
Like i've seen heaps of fellas making their own custom dash and all, but how do u fix the damn thing on to the dash rails.
need ya help fellas, stumpped
much appretiated
twista
PostPosted: Wed Mar 30, 2005 8:33 pm
i drilled a plate to the side of the car (one on each side) in the middle of the 2 dsh rails, so you srew it into them, 2 screws on each side, all it needs!
Potato
PostPosted: Wed Mar 30, 2005 8:39 pm
Here's the back of a bought one [still at the shop LOL]
check out the bracket with the wing nuts on it - it might give you a couple of ideas
PostPosted: Wed Mar 30, 2005 9:08 pm
Dats noyce whodat
PostPosted: Wed Mar 30, 2005 10:13 pm
yea, thats how they factory rover ones are.
I am not keen on drilling and screwing into my rails, so I'll take option 2 :wink:
PostPosted: Wed Mar 30, 2005 10:35 pm
so how exactly do those |_____| brackets work? .....
twista
PostPosted: Wed Mar 30, 2005 10:46 pm
they hook in behind the top and bottom rails.
have one in the middle and at each end of the custom dash
reach up from underneith to do up the wing nuts
PostPosted: Thu Mar 31, 2005 10:02 am
Yours is a clubby right? If so there should be two screws holes in the top dash rail that used to hold in the radio I used these and a piece of aluminium that holds my dash in. It depends on what you dash looks like though, I didn't like the idea of making more holes than strictly nessicary either JAM
Roads need more corners
PostPosted: Thu Mar 31, 2005 11:26 am
ahhhk thats seems quite easy, i think i will do the bracket, but what about the cluster of guages, you know the standard clubman ones, i have 2 in that twin cluster, and my tacho is sitting on its own to the side, and that cluster protrudes out further so how do these gauges fit exactly into place behind the dash face?
PostPosted: Thu Mar 31, 2005 12:09 pm
take off the binical surround [the plastic bit that is sticking out too much] from your 2 gauge instrument cluster
the dash now fits up flush to the instrument cluster glass
your tach and any other accillary gauges get mounted directly onto the board of the new dash [you may need surface mounting brackets if your tacho is currently pod mounted]
have fun
Dat
PostPosted: Thu Mar 31, 2005 5:48 pm
ahk, so there shouldnt be any adjustments with gauges
so it fits flush hey? it looks lke it'll protrude further out
twista
PostPosted: Thu Mar 31, 2005 7:31 pm
Look closer at the pic above - see how they have used several layers of the wood to make it sit out a bit to allow for that difference around the gauges and the slight differece in the angle of the glass compared to the dash. Plagerism is the highest form of flattery.
PostPosted: Fri Apr 01, 2005 5:41 pm
ahk kool, well i'll post some pics let ya'll know what it turns out...thanks
i'll get stuck into these skool holidays
PostPosted: Fri Apr 01, 2005 6:22 pm
Now is a clubby differnt...as to reach up in a Round Nose..New Idea :?
PostPosted: Fri Apr 01, 2005 6:56 pm
Well my pacel shelf is covered by vinyl covered board, but the frame supporting this is just that a frame not solid metal. There is a very large opening on each side of the car along the parcel shelf, more than adiquate to get a hand up in behind a custom dash.
I have a clubbie but with a centre clock Morrie dash [one of those povety pack government specials] so I wouldn't be at all surprised if your roundie dash was the same.
