It is currently Sat Jun 28, 2025 3:12 am
 Post subject: Engine costs?
PostPosted: Thu Mar 31, 2005 3:18 pm
I was wondering if anyone had a price on a completley rebuilt 1380 engine that would give about 100bhp and gear box to suit If it were in qld like the Gold Coast or Brissy I would like to know This price that I was looking for included the running gear aswell like the radiator and things like that.
Any help is greatly appriciated
Pat
_______________________________________________
Team MADMAN/Pat Rogers
PostPosted: Sun Apr 03, 2005 6:41 pm
ok here goes first all the work was carried out by LW parry in sydney ph 9599 2871
they gave me heaps of help and explained everything to me (this was the first time i had built an engine.) but my dad was a mech engineer and he said the machining was really good and was very happy.
* chemical clean of engine and component $55
* messure check inspect & report $27
*remove and replace welsh and gallery plugs $39.60
*rebore and houn 4 cylinder to suit piston $148.50
*surface grind cylinder block face $59.40
*remove and relace cam bearings $36.30
*contour grind 8 cam followers faces $35.20
*demantel and rebuilt & align 4 piston and conrod $48.40
* bore and hone 4 conrod tunnels $66
*crack test 1 cylinderhead $27.50
*recondition & surface grind of 1 cylinderhead $148.50
* remove and replace ring gear (not part of engine rebuild) $27.50
* supply 1 set of pistons and piston rings $244.20
* 1 set of conrod bearings $63.80
* 1 set of main bearings $69.30
* 1 set of main bearings thrust $13.20
* 1 set of gallery and welsh plugs $33.00
* full engine gasket set (1275) $96.80
* 1 competition exhaust valve $46.20
* 1 ring gear $86.90
* remove and replace 4 exhaust valve guilds $22
*supply 4 exhaust valves $28.60
* 8 conrod nuts $44
*Delivery fee $5.50
price exclude GST
TOTAL including GST $1499.30
I got the cam reground later at the same place for $121 including GST
that is the cost of a rebuild i have the peices to do this rebuilD sale if your intrested.
PostPosted: Sun Apr 03, 2005 6:43 pm
* 8 conrod nuts $44
*Delivery fee $5.50
price exclude GST
that is the cost of a rebuild i have a 1310 in peices but it need a rebuild it's a good build block for a 1380. it is a s block also
PostPosted: Mon Apr 04, 2005 8:09 pm
how much you selling your engine for
(just to be able to work out what a complete swap would cost) :wink:
