https://ausmini.com/forums/
Tightening up a rod-change....
https://ausmini.com/forums/viewtopic.php?f=5&t=5935
Author:  kazjim [ Wed Mar 30, 2005 2:35 pm ]
Post subject:  Tightening up a rod-change....
Ok, I'm adding up the $$$ for my 'box rebuild... (getting scary. . . )
The Shifter is next...
Whats the wear parts ?
just the ball on the end of the stick ?
the "coupler" that goes between the rod and the gearbox input ?
what to replace ??
J
Author:  Lillee [ Wed Mar 30, 2005 2:39 pm ]
Good question, I too would like to know this...
Sorry didn't answer your question :oops:
Author:  aaron [ Wed Mar 30, 2005 2:55 pm ]
Wear parts will be the fork and ball on the end of the shifter, and also the rod to ball inside the box. There the metal bits. I am pretty sure you will also need to replace a nylon cup inside the shift mechanism. Don't know too much about the ole rod change as i have mostly delt with remotes.
Aaron
Author:  Lillee [ Wed Mar 30, 2005 3:23 pm ]
:shock: Forget it too much work :lol: . To tighten up a rod change the easy way is to conver to a remote change! :lol:
Author:  Christoph [ Wed Mar 30, 2005 4:33 pm ]
The cup on the end of the rod that the ball goes in also wears, i think new ones are hard to get or expensive -either of the two because i remember one of our club members bringing one to a meeting wanting to machine a new one from scratch :shock: . The balls also wear on the stick but are harder material than the alloy cup/union bit. The other obvious ones are the cotton reels and the rubber bush/sleeve that holds the steady bar to the back of the diff.
Author:  drmini in aust [ Wed Mar 30, 2005 7:28 pm ]
re the rubber bush in front of the steady bar..
it's allergic to oil. Yeah that's right. :lol: No wonder the bastards self-destruct..
I made one for our Clubbie from polyurethane rod, but Mini Mad's car has a steel bush in there. No vibration, no slack. It's all good! (for a rodchange..) :P
Easy to fit too.
Author:  kazjim [ Wed Mar 30, 2005 7:59 pm ]
I'll start with a steel bush and replace the link piece... (mine wobbles real nasty like..)
see how it goes....
Thanks, I'll report back...
J
Author:  Spaceboy [ Wed Mar 30, 2005 10:48 pm ]
get a replacement from a later model uk mini or sommit, the late ones were all rod change
