Heater Exchange Radiator https://ausmini.com/forums/viewtopic.php?f=5&t=59326 |
Author: | mini is my ride [ Sat Dec 05, 2009 11:52 am ] |
Post subject: | Heater Exchange Radiator |
I was talking to a mini person the other day and he said with some of his cars he used the heater exchange as an extra radiator mounting outside the front of the car. I don’t know if anyone else has tried this but he said it works |
Author: | Gadgets mini [ Sat Dec 05, 2009 12:49 pm ] |
yep i got one mounted below the bumper just inside the engine bay i got a two "t" pieces plumbed in and two taps so i can select either the indorre heater for winter and direct it outside for the summer. that way i can still have the fan on in summer to bring outside air in without it being heated up it works a treat |
Author: | Morris 1100 [ Sat Dec 05, 2009 7:38 pm ] |
Gadgets mini wrote: yep i got one mounted below the bumper just inside the engine bay
i got a two "t" pieces plumbed in and two taps so i can select either the indorre heater for winter and direct it outside for the summer. that way i can still have the fan on in summer to bring outside air in without it being heated up it works a treat I didn't know you had a Mini. ![]() |
Author: | drmini in aust [ Sat Dec 05, 2009 7:43 pm ] |
I have one of those stock in my `wasa Minimatic', it's called a fresh air heater. Works real good at keeping the 1360 cool. ![]() <edit> a Clubby heater core fits nice in a roundy, between the alternator and the dizzy. Attach it to the grille vertical strut with some cable ties, and rubber strip in between. Cut the 2 pipes off a bit, as they are too long. No need to flare them though with wormdrive hoseclamps. |
Author: | david rosenthal [ Sun Dec 06, 2009 12:32 am ] |
I have set up a big oil cooler unit off a saab turbo as a radiator for cooling. the cooler runs" paralell" to the radiator/ heater core. the fitting on the head has a 3 way v/v and the outl let of the heater had a "T" fitting running back to the radiator hose into pump. When it's 40 + the water passes thru the "cooler" which is mounted similar to rad but on R.H side. then in winter the cooler is by-passed and the heater is used. |
