It is currently Mon Aug 18, 2025 10:04 pm
 Post subject: Heater Exchange Radiator
PostPosted: Sat Dec 05, 2009 11:52 am
I was talking to a mini person the other day and he said with some of his cars he used the heater exchange as an extra radiator mounting outside the front of the car.
I don’t know if anyone else has tried this but he said it works
PostPosted: Sat Dec 05, 2009 12:49 pm
Resident Haemorrhoid
yep i got one mounted below the bumper just inside the engine bay
i got a two "t" pieces plumbed in and two taps so i can select either the indorre heater for winter and direct it outside for the summer. that way i can still have the fan on in summer to bring outside air in without it being heated up
it works a treat
mtsmini wrote:
Tombo wrote:
PostPosted: Sat Dec 05, 2009 7:38 pm
it works a treat
I didn't know you had a Mini. :shock:
PostPosted: Sat Dec 05, 2009 7:43 pm
I have one of those stock in my `wasa Minimatic', it's called a fresh air heater.
Works real good at keeping the 1360 cool. 8)
<edit> a Clubby heater core fits nice in a roundy, between the alternator and the dizzy. Attach it to the grille vertical strut with some cable ties, and rubber strip in between.
Cut the 2 pipes off a bit, as they are too long. No need to flare them though with wormdrive hoseclamps.
Last edited by drmini in aust on Sun Dec 06, 2009 9:06 am, edited 1 time in total.
PostPosted: Sun Dec 06, 2009 12:32 am
I have set up a big oil cooler unit off a saab turbo as a radiator for cooling.
the cooler runs" paralell" to the radiator/ heater core. the fitting on the head has a 3 way v/v and the outl let of the heater had a "T" fitting running back to the radiator hose into pump.
When it's 40 + the water passes thru the "cooler" which is mounted similar to rad but on R.H side. then in winter the cooler is by-passed and the heater is used.
www.minisprintgt.com
