Front Subframe Mounts (attention Mini Matic Peeps) https://ausmini.com/forums/viewtopic.php?f=5&t=5872 |
Page 1 of 2 |
Author: | drmini in aust [ Mon Mar 28, 2005 4:04 pm ] |
The Rovers have a rubber mount there. Best thing you can do on your 850 is get a solid steel or alloy spacer machined up to fit in. ![]() |
Author: | JC [ Mon Mar 28, 2005 5:26 pm ] |
You mean like this? http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=4537286132&ssPageName=STRK:MEWA:IT I can't see how it works... |
Author: | drmini in aust [ Mon Mar 28, 2005 7:10 pm ] |
Maybe those things fit to the later subframe? On yours, I'd either turn something up, or weld a washer in the hole, then put a spacer behind it. ![]() |
Author: | Boostedmini [ Thu Mar 31, 2005 8:51 am ] |
sorry i do not understand, correct me if i am wrong but the hole is where the caster arm pokes through yes? and the little hole you can see below is where the subframe mounts too, and you have only replaced the outer beever panel (painted section) or have you replaced the front apran assembly ? |
Author: | gafmo [ Thu Mar 31, 2005 6:46 pm ] |
I'v only Every Seen a Bolt and Washer's Here..Am I wrong ![]() |
Author: | mickmini [ Thu Mar 31, 2005 7:01 pm ] |
you can get off the shelf solid subframe mounts from the UK. but the subframes are different too ithink |
Author: | JC [ Sun May 15, 2005 3:58 pm ] |
Can someone do me a favour. I need a photo of a standard roundnose front subframe mount setup. I looked at SG's yesterday and his appears to be the same as mine. Photo will need to be taken from inside the engine bay down towards where the subframe mounts to the body......and post it up. |
Author: | dani [ Sun May 15, 2005 4:57 pm ] |
Just took some pictures for you ... It's been awhile since I last went on here how is everybody? Thanx for the strawberry cruisers... Hows your battered banana ![]() ![]() ![]() And dad took this photo of me while i was out there ![]() |
Author: | simon k [ Sun May 15, 2005 4:58 pm ] |
whitestriped63, I owe you one, if you han't asked for photos, I wouldn't have taken these and realised that I'd forgotten to do up the front bolts on my S after I put it together.... nice work ![]() basically, it looks like you're missing the small panel that goes from the top of the beaver (tee hee hee ![]() ![]() ![]() ![]() ![]() |
Author: | simon k [ Sun May 15, 2005 5:02 pm ] |
dani wrote: And dad took this photo of me while i was out there
![]() I hope that roof was dented before you sat on it Dani - otherwise you're in big trouble |
Author: | JC [ Sun May 15, 2005 5:07 pm ] |
dani wrote: Hows your battered banana
![]() Dani, i'm not talking to you about any crumbed bananas, your dad looks like he can fight.. Thanks for the pics. Can you take one from inside the engine bay looking down at where the frame mounts to the body? JC |
Author: | dani [ Sun May 15, 2005 5:08 pm ] |
those pics are better than mine, but i did it special, so its going up ![]() ![]() |
Author: | gafmo [ Sun May 15, 2005 5:09 pm ] |
Sk I'd be doin us that nut and bolt for the sub frame and Dani..Get off that roof NOW ![]() Go to you Naughty seat and stay thier till you relaised what you have just Done ![]() ![]() |
Author: | sg [ Sun May 15, 2005 5:10 pm ] |
dani wrote: Just took some pictures for you ... It's been awhile since I last went on here how is everybody? Thanx for the strawberry cruisers... Hows your battered banana
![]() OMG post of the year Dani, that is GOLD ![]() ![]() This be a QLD chapter of Ausmini joke for all the others down south... |
