Evacu-pan crankcase ventilation... https://ausmini.com/forums/viewtopic.php?f=5&t=58454 |
Author: | Asphalt [ Tue Nov 03, 2009 3:05 am ] |
Post subject: | Evacu-pan crankcase ventilation... |
Hi! Anyone runing such a system? Especially reliability would be interesting (such as durabillity of the catch valves). Is it actually worth it for a road motor (1275cc, ~100hp)? I'm probably going to fit a K head so good vacuume would help oil drain a bit I guess. But if you have to put in a new valve with every oil change (daily driven) I'd be quite annoyed ![]() And final question: what would be a sensible (negative) pressure level? I don't want it to suck all the oil out of bearings or such ![]() Cheers, Jan |
Author: | KLAS [ Tue Nov 03, 2009 5:30 am ] |
i could give you some parts ![]() just in case you want to try yourself |
Author: | TheMiniMan [ Tue Nov 03, 2009 9:21 am ] |
we had it in one of our speedway cars years ago (The superCharged one) , but it didn`t seem to be any different to the breathers just shoved into a catch bottle tho,,, altho it was "Less-smelly" in the engine bay ![]() & sorry, no idea how low the pressure was, |
Author: | albino235 [ Thu Nov 05, 2009 8:04 pm ] |
I have no experience with it myself so I thought I'd consult vizard. He claims power gains by using positive ventilation, aparantly his tests indicate around 2hp on a big bore engine. He also says that he achieved up to 36" of water which is quite a lot! A few points he makes are; - after about 15" of water the seals start letting in air - under vacuum the dizzy doesn't recieve enough lubrication and so it will need greasing regularly - The dipstick will also let in unfiltered air But on his diagrams he doesn't show any pressure limiting valve so perharps the pressure limiting is by design? |
Author: | Asphalt [ Tue Nov 10, 2009 10:54 pm ] |
Interesting ![]() ![]() @Klas: I'll come back to you. Might take a little time tho ![]() |
