It is currently Sat Jun 28, 2025 9:45 pm
PostPosted: Sun Mar 20, 2005 8:01 pm
I got the metro discs and hubs. Need to buy the earlier model ball joints as the later model ones are larger and tappered. Got my bottom arms out, got the later model ball joints. No major hassle there.
Lugged the damn things out. I thought f@rk these are heavy, this is going to slow Striped down a hell of alot. So I yell to the other half to bring me the scales. 14kg's each, no driveshafts attached!
Questions.....
Considering these Hondas are using the drum brake hub, how much does the set up weigh? How much does a standard drum and disc brake hub assembly weigh?
Do i need to grin off the things that protrude from the flange face?
Does it matter that I broke one of the bleed niples off?
PostPosted: Sun Mar 20, 2005 9:30 pm
I know the Hondas are a little lighter. Swivels hubs- drum or disc are almost the same, calipers are where the weight is.
WTF don't they make them alloy.. :lol:
Yes you can machine or grind those lumps off the drive flanges. :wink:
PostPosted: Mon Mar 21, 2005 10:08 am
yes it does matter u snapped off the nipple, id take it yto a brake place and get it fixed mate ;)
lookin for another clubby
PostPosted: Mon Mar 21, 2005 6:27 pm
I knew I was f@rked when i broke the nipple off but was just praying that it wasn't entirely necessary. Thought the the calliper could just be bled from the other nipple.
PostPosted: Mon Mar 21, 2005 7:22 pm
im running performance 13x6's and i didnt have to take them lugs off. I also broke a nipple on one of my calipers,, will need to get that fixed soon too.
1974 Moke - 998cc
PostPosted: Tue Mar 22, 2005 12:11 pm
Brad I think it depends on the wheels you run as to whether you grind off the lugs, I've read that the lugs have to come off on just about every article concerning metro brakes! Performance rims must have a larger centre hole than some other rims :?:
PostPosted: Tue Mar 22, 2005 3:00 pm
yeh it is a very tight fit,, so close that that the actual paint on the wheels makes them not fit,, but once that is removed they fitted on :shock:
1974 Moke - 998cc
