It is currently Fri Jun 27, 2025 6:17 am
PostPosted: Sun Mar 27, 2005 4:06 pm
Pulled this off MiniMania site. Looks sweet, except LHD only, as the ^(&$*@ RHD Mini rack is in the way of the diff.
http://www.minimania.com/web/startretur ... thread.cfm
PostPosted: Sun Mar 27, 2005 5:39 pm
What about an alternative rack ?
Maybe a Gemini or Miata one ?
anyone investigating ?
J
PostPosted: Sun Mar 27, 2005 6:51 pm
IF you can work out how to move the RHD rack rearwards by 1-1/2", it'll fit.. 8)
Shouldn't be rocket science, ay!
PostPosted: Sun Mar 27, 2005 10:37 pm
I was reading on the 16 valve forum where the UK guys are having problems with the floor pans in their Honda conversions around the rear mount area. It appears to be bending the floor pan. Much debate on the correct type of strengthening that appears to be needed. There again most of them appear to be manic leadfoots.
Chris
Everything I like is either
PostPosted: Mon Mar 28, 2005 12:06 am
If somebody was going to the trouble of fitting a VTEC into their shell, its probably at a point where cutting and welding the shell is not a problem....
In this case, could they GRAFT a channel into the floor that the steering rack would recess into?? The only problem I would see with this is the allowable pedal travel distance would be halved :? That would be a problem, I guess :lol:
