Errrrr ,,,, Help ...BMW Bike engine head conversion https://ausmini.com/forums/viewtopic.php?f=5&t=52283 |
Page 1 of 2 |
Author: | Doyle45 [ Sun Apr 19, 2009 12:44 am ] |
Post subject: | Errrrr ,,,, Help ...BMW Bike engine head conversion |
OK call me stupid... I am just catching up on the fact you can put the BMW bike engine on the A series block Sooooo ... how hard is this, can you do this to an injected car ( I assume you run 2 ECU's) does anyone do the conversion here in Melbourne ? what power result do you get ? Cost ????? I am also looking at a supercharger kit from the UK to bolt on my MPi injected car ... its 3200GBP before importing and fitting .... does anyone do this here already ??? thanks for your time Gav |
Author: | d1ck0 [ Sun Apr 19, 2009 9:12 am ] |
Post subject: | Re: Errrrr ,,,, Help ...BMW Bike engine head conversion |
Doyle45 wrote: OK call me stupid...
I am just catching up on the fact you can put the BMW bike engine on the A series block Sooooo ... how hard is this, can you do this to an injected car ( I assume you run 2 ECU's) does anyone do the conversion here in Melbourne ? what power result do you get ? Cost ????? I am also looking at a supercharger kit from the UK to bolt on my MPi injected car ... its 3200GBP before importing and fitting .... does anyone do this here already ??? thanks for your time Gav Talk to Matt (TheMiniMan) as he makes the kits to install them. No doubt you've seen his post here http://www.ausmini.com/forums/viewtopic.php?t=46276 Also David Rosenthall has created a way to fit Honda CBR600F3 heads on too. Very Nice.... Matt's in Brisbane, David's in Adelaide (which might be better as you're in Melb and closer. Hope this helps. Dicko Dicko |
Author: | Kennomini [ Sun Apr 19, 2009 10:11 am ] |
From what I understand about Matts BMW head conversion you would simply ditch the mini head, ecu, engine wiring (to an extent) and replace it with the BMW head, ecu (if you wanted that set up as you can simply use the std BMW carbys) and you would use the BMW ecu wiring loom. I think the price for a kit is around (don't quote me) $1500 plus a head ($250-$500ish) and the maching needed for the block. As for power unfortunately Matt hasnt had the opportunity to test this exactly but I think a ball park figures is around holly sh!t that's fast ![]() As for the supercharger kits their is a few places in Australia that do them, Link Automotive springs to mind. The fun you would get from an SC set up on a mini plus the power would be a very good combination and it's still a true A series engine. |
Author: | justfanginaround [ Mon Apr 27, 2009 9:25 pm ] |
i am able to help with fitting them in Melbourne and I have done all the machine work to a mates engine for him. |
Author: | simon k [ Tue Apr 28, 2009 11:00 pm ] |
Doyle45 wrote: I am also looking at a supercharger kit from the UK to bolt on my MPi injected car ... its 3200GBP before importing and fitting .... does anyone do this here already ???
Ben aka 92 does a supercharger kit - under $1000 for the kit, plus about $300 for the blower off a toyota 4AGZE, and a HIF44 carb does the UK kit work with MPi? |
Author: | Harley [ Wed Apr 29, 2009 8:36 am ] |
simon k wrote: does the UK kit work with MPi?
It could be an eaton conversion. They've had some success with them. ![]() |
Author: | TheMiniMan [ Wed Apr 29, 2009 4:20 pm ] |
http://www.youtube.com/watch?v=6oGTWNlPWe8 first up i must appologise for being so slow to sort out dyno figures for you all,,, I`m getting there with this turbo injected twin cam 16v moke,,, i just don`t get much time to play with the tuning of it cause i`m always surfing instead ![]() & the small bore twin cam runs a treat now too,,, It`s now in the car & running well on the carby, but we`re changing it over to injection now also http://www.youtube.com/watch?v=nticl79XXKE Figures from some of the guys in England are showing very smooth grunty 110hp-ish from N/A 1293cc 8v donks,,,, & over 200hp so far from Jimsters Turbo twin cam16v version,,, so obviously there`s way more avaliable |
Author: | meeni [ Wed Apr 29, 2009 5:39 pm ] |
latest mini mag i have has a special k head dyno day on it and shows jim lyons turbo twin cam as mentioned above showing 216 bhp@ the wheels with a slipping clutch and 10 psi down on what it should be running ![]() |
Author: | TheMiniMan [ Wed Apr 29, 2009 9:04 pm ] |
hee hee,,, that`s my Jimster ![]() ![]() |
Author: | simon k [ Wed Apr 29, 2009 10:25 pm ] |
meeni wrote: latest mini mag i have has a special k head dyno day on it and shows jim lyons turbo twin cam as mentioned above showing 216 bhp@ the wheels with a slipping clutch and 10 psi down on what it should be running
![]() fark... ![]() that's a lot of bananas in any language! |
Author: | Ziegech [ Fri May 01, 2009 2:31 pm ] |
where in melbourne are you? some time in the future i could let u try out bens supercharger kit in my car. has a few benifits like detuning later on and no body mods. Is easy to bolt together and link are happy to tune the kits up aswell. |
Author: | Doyle45 [ Fri May 01, 2009 4:36 pm ] |
[quote="Ziegech"]where in melbourne are you? some time in the future i could let u try out bens supercharger kit in my car. has a few benifits like detuning later on and no body mods. Is easy to bolt together and link are happy to tune the kits up aswell.[/quote] Hi, and thanks Can you get me in touch with ben as well ?? I am in Seddon, which is between Footscray and Yarraville .... not far from you I think ? Gav |
Author: | sgc [ Fri May 01, 2009 5:38 pm ] |
Doyle45 wrote: I am in Seddon, which is between Footscray and Yarraville .... not far from you I think ?
Gav Not far from me either.. goody goody, another Mini in the area ![]() |
Author: | EWGA MINI [ Sun May 10, 2009 7:58 am ] |
Doyle45 wrote: Ziegech wrote: where in melbourne are you? some time in the future i could let u try out bens supercharger kit in my car. has a few benifits like detuning later on and no body mods. Is easy to bolt together and link are happy to tune the kits up aswell. Hi, and thanks Can you get me in touch with ben as well ?? I am in Seddon, which is between Footscray and Yarraville .... not far from you I think ? Gav John (Justfanginaround) Is helping with my project. You are more than welcome to come have a look if you like, at the moment the engine is dummy fitted to the car in order to get an idea of where things fit. I have a mini 1963 / 65 round nose. We had to modify the bonnet to accomodate the engines extra height, and we are still scratchin our heads trying to figure a way of doing the induction without destroying the look of the car. Specs are 1275 block bored out to 1390cc, running BMW 8V k100 head conversion (Mad Matts set up) , hoping to fuel inject it, running full Siemans VDO guages, KAD race brakes front and back, with 13x6 inch Yokohamma race rubber ![]() ![]() Machining $1,300 Used BMW engine $550 Pistons $440 Conversion Kit $1,300 to 1,500 i think, not exactly sure hi flow radiator $550 and still counting hehehe. It will be a wait before the car is opperational, however it should go like the clappers ![]() I will have it on display as a static work in progress at the mini 50 show comming up ![]() Cheers Andrew |
Author: | TheMiniMan [ Sun May 10, 2009 9:35 am ] |
HI Andrew, glad to see you again ![]() ![]() & on one of our twinkys we run a set of short bell-mouths on the std throttle bodies with 4x foam filter pods & they all fit neatly under the bonnet,,, so don`t stress about room or clearance for induction,,, it`s not a problem |
