Broken Engine Steady https://ausmini.com/forums/viewtopic.php?f=5&t=5175 |
Page 1 of 2 |
Author: | Anto [ Tue Mar 01, 2005 11:45 am ] |
Post subject: | Broken Engine Steady |
G'day Guys, I've got a slight problem with the Mini which I'm looking for advice on. The clutch end engine stabiliser bar is broken - both the top and bottom bracket on the bulkhead have snapped. This leaves me with online the radiator side steady bar, making the car not very driveable. Replacing the top bracket is relatively easy, just have to take the master cylinders out, but the bottom bracket is the problem. It has snapped along the right-angled bend. I'm guessing it's loads of fun to replace requiring engine removal and an experienced welder. Are there any other solutions available? Could I for example add two lower engine steadies aswell as the radiator one, and not have a clutch end stabiliser bar? I've seen the wonderful adjustable steady bars available, are there any available that work as a replacement for my broken one? I've seen kits for the engine side of the bracket for those of us with broken studs, but no kit for those of us with broken brackets on the firewall! Anyone have any solutions, temporary or not, that wont require engine removal at this point in time? The timing is not right for an engine removal. If it had happened two weeks ago, I'd have been fine! Anto. |
Author: | Zizzle [ Tue Mar 01, 2005 12:04 pm ] |
I remember welding mine (firewall bracket that is). Can't remember whether the engine was in or out. Whoever had the car before me was very fond of brazing things. Braze and bog actually. So I had to clean the braze off both parts, but giving it a hit with the mig was pretty straightforward. The Mig weld seems to be holding up much better than the braze for some reason ![]() |
Author: | WhoDat [ Tue Mar 01, 2005 12:06 pm ] |
If that bracket is broken off as you say then would this work??? Drill a couple holes thought where the bracket is still welded to the firewall and get a piece of angle to bolt on as a replcaement. It would not need removal of engine to do, this location already has some re-inforcing of the firewall from the old bracket, but I would put a bit of flat in there as well on the inside. A propper replacement could be welded in at a later date when the engine is comes out for anonther reason. but it should be strong enough to last for years I'd think. Like this ![]() I'm no engineer so I defer to the experts if this presents ant safety or other issues. Cheers Dat ps The pic is an optical illusion - go Photoshop LOL |
Author: | Anto [ Tue Mar 01, 2005 1:41 pm ] |
I had thought of drilling holes and bolting the bracket in - I was a bit worried it might pull through though. Using a big washer on the top bracket didn't help, possibly made it worse. The top bracket snapped right along the edge of the washer. How much room is there to play with on the other side (ie where the pedal box is). I am assuming I have access from the inside of the car, judging by your picture (I haven't had a chance to look myself yet). I'm thinking your idea might just work, at least for the time-being. I was going to remove the engine again at some stage, but I'd prefer to put a 1275 back in ![]() Anto. |
Author: | mickmini [ Tue Mar 01, 2005 3:08 pm ] |
I had a problem where the steady bar had pounded the firewall enough to crack it. We welded the crack up, then a 3mm plate over the top, then welded a bit of angle to that, using a washer welded to that to make a nice round surface for the bottom bush to sit against. all that was done with the engine in the car. also welded a washer inside the top of the top bracket to reinforce that. i don't think i'll have that problem again. ever ![]() all done with a stick welder too, so if you cant get the MIG nozzle in there, that is an option. michael |
Author: | Flashback [ Thu Mar 03, 2005 10:47 am ] |
Try this link from Minimani in the states. Probably more useful for ones that haven't broken yet but worth a look anyway http://dealer.minimania.com/web/Item/MSSK1500/AddedFrom/CatBrowse%2D%20ENGINE%5FSTABLIZ/InvDetail.cfm |
Author: | WhoDat [ Thu Mar 03, 2005 12:59 pm ] |
Anto wrote: How much room is there to play with on the other side (ie where the pedal box is). I am assuming I have access from the inside of the car, judging by your picture (I haven't had a chance to look myself yet).
Anto. There is tons of room ![]() If you remove the pedal box and master cylinders you'll have all the room you need to get in there and do the job. [on the inside, there is a cavity on the firewall for the mastercylinder push rods to enter the cabin. This is all within the confines of the pedal box, so removing it would save lots of swearing and skun knuckles] As long as the bolts you use for this mod don't stick too far rearwards into the cabin you'll be fine - the first thing they could come in contact with will be the master cylinder push rods which line up central to the large horizontal hole in the pic so you got a significant amount of clearance to have a backing plate and head of a nut on the inside of the firewall. Cheers Dat |
Author: | CLUBMAN [ Thu Mar 03, 2005 1:17 pm ] |
my most hated job on a mini,getting master cylinders out of minis,HATE IT ![]() |
Author: | bigel nigel [ Thu Mar 03, 2005 1:52 pm ] |
don't forget about puttind them in ur that all that good at that etheir ![]() ![]() |
Author: | CLUBMAN [ Thu Mar 03, 2005 2:59 pm ] |
dont trust bigel with rear subframes,when PUSHING cars they callaps and almost take your arm off from the top of the door ![]() |
Author: | bigel nigel [ Thu Mar 03, 2005 4:03 pm ] |
but i am really quick when it comes to droppin engines in ![]() ![]() ![]() ![]() ![]() |
Author: | CLUBMAN [ Thu Mar 03, 2005 4:10 pm ] |
get her over the car,give engine lifter a 1/2 turn and she home and hoasted..WOW that could have taken stevs arm off ![]() ![]() |
Author: | Anto [ Fri Mar 04, 2005 1:12 pm ] |
Flashback wrote: Try this link from Minimani in the states. Probably more useful for ones that haven't broken yet but worth a look anyway
http://dealer.minimania.com/web/Item/MSSK1500/AddedFrom/CatBrowse%2D%20ENGINE%5FSTABLIZ/InvDetail.cfm That kit looks like the gear I need. However, it is not available locally and I think ordering it from O/S would take too long. At this point in time I think I will get another lower bracket off a parts car, and put a couple of bolts through to hold in on with some big flat washers to spread the load. Will probably be better than the original spot welds ![]() I will also look in to adding some lower engine stabiliser bars. They are a bit costly but I may have to bite the bullet if I want to avoid this problem in the future. Anto. |
Author: | min13k [ Fri Mar 04, 2005 1:19 pm ] |
hey anto is it remote or rod change ?? makka |
Author: | Anto [ Fri Mar 04, 2005 1:35 pm ] |
rod change. Which makes bottom engine steadies even more important! |
