It is currently Thu Jun 26, 2025 5:12 pm
 Post subject: Give it a good reaming
PostPosted: Sun Feb 20, 2005 5:29 pm
I just bought the overhaul kit for the rear suspension arms and it says something about having to ream the outer bronze bush with service tool 18g 588 etc etc. I there a way I can do this without having to find a service tool.
Matt
PostPosted: Sun Feb 20, 2005 6:00 pm
Online
Not really. :cry: If you have a 13/16" adjustable reamer, you can fit a guide bar to it and a bush to locate in the other end needle bearing.
If not properly reamed in line, the shaft won't go thru... :x
If you find a Mini repair place, most have a reamer for this job. I got mine done by Mini Classic in Ermington, Sydney. :wink:
PostPosted: Sun Feb 20, 2005 6:09 pm
Matt, PM sent...cheers, Mick
