a+ block? https://ausmini.com/forums/viewtopic.php?f=5&t=4861 |
Author: | ausminis4u [ Thu Feb 17, 2005 9:05 am ] |
Post subject: | a+ block? |
hey guys just been thinking this morning, can a pre a+ dizzy be fitted to a a+ block? ( i know about drive changes, but is the mounting face the same? |
Author: | 1380 yellow devil [ Thu Feb 17, 2005 1:46 pm ] |
Not to sure I think the mouting bracket is different but I would need to look at the one in the shed to see if the whole dizzy is same and ahs the provisions for the old style mounting bracket. |
Author: | MiNi MuLiShA [ Thu Feb 17, 2005 2:18 pm ] |
Hey, I have a rear wheel drive a+ in my sprite and all i had to do is change the drive... all the rest is the same, cant b sure ther the same asa mini tho... -Cam ![]() |
Author: | drmini in aust [ Thu Feb 17, 2005 6:25 pm ] |
I'm about to convert my Pulsar D4R85 dizzy from A series to A+ for Barney's 1293. The A+ drive dog is different, the roll pin is smaller, and once I run a file around the Pulsar dizzy's body (or stick it in the lathe) the A+ finger clamp will work fine. ![]() Diameter and body length of A series and A+ dizzys are pretty much the same. |
Author: | ausminis4u [ Fri Feb 18, 2005 11:55 am ] |
drmini in aust wrote: I'm about to convert my Pulsar D4R85 dizzy from A series to A+ for Barney's 1293. fair enough, im just thinbking if i get an A+ block will i be able to use my honda dizzys?
Author: | drmini in aust [ Fri Feb 18, 2005 8:20 pm ] |
Yes, I've take mine out already and it will fit. Maybe next week, A+ motor is still not quite in car yet.. ![]() |
Author: | CLUBMAN [ Sat Feb 19, 2005 12:53 am ] |
The mounts on the A+ 1275 motor (from what iv seen) use a diffrnt type of mount,but if you buy a late nuff A+ motor it may well have elec. ignition in it? OR are you already in on the pulsar dizzy thing?,they do sound like a good idear,but id be tempted to leav my stuff mini with a pertronic kit if i could |
Author: | drmini in aust [ Sat Feb 19, 2005 5:59 am ] |
CLUBMAN wrote: The mounts on the A+ 1275 motor (from what iv seen) use a diffrnt type of mount,but if you buy a late nuff A+ motor it may well have elec. ignition in it?
OR are you already in on the pulsar dizzy thing?,they do sound like a good idear,but id be tempted to leav my stuff mini with a pertronic kit if i could Yes, A+ block mounts it different but the Pulsar dizzy can be modded easy to do both. I've had a Pertronix- they work, but they don't fix the worn bushes and advance mechanism that are a feature of all old Lucas dizzys. I have yet to find a Pulsar dizzy with any slack in it- they are beautifully made by Mr Hitachi. re the late electronic Lucas- much of the above applies, and they have had problems with external ignition modules. Pulsar dizzy has it all under the cap... neater system. ![]() |
Author: | CLUBMAN [ Sat Feb 19, 2005 10:42 am ] |
Do the pulsar dizzys use a ignition coil of there own,or can it be wired to the mini one already on the car? |
Author: | drmini in aust [ Sat Feb 19, 2005 12:04 pm ] |
Pulsar dizzy uses a standard 1.5 ohm `resistor' coil (but without a resistor), not the 3 ohm Mini one. For $40 at the wreckers we get the Pulsar dizzy, coil, cap & leads too.. Bosch GT40-R coil works OK with the Pulsar. ![]() |
