Single Wiper Mod for Mini ???????? https://ausmini.com/forums/viewtopic.php?f=5&t=42423 |
Page 1 of 2 |
Author: | bquick [ Mon May 26, 2008 10:22 pm ] |
Post subject: | Single Wiper Mod for Mini ???????? |
Does anyone know of a single centre wiper mod for mini's? Cheers, Ben ![]() 1960 Mini 850 (1999 Rover 1275 MPI) |
Author: | Kennomini [ Wed May 28, 2008 9:26 pm ] |
You'd need a wiper motor that travels close to 180 degrees ![]() |
Author: | Morris 1100 [ Wed May 28, 2008 9:28 pm ] |
Just take the left one off. |
Author: | norton [ Wed May 28, 2008 9:50 pm ] |
I don't reckon it could work, the screen is not like a modern car which is about as tall as it is wide |
Author: | drmini in aust [ Wed May 28, 2008 10:42 pm ] |
If you use early wheelboxes with a Clubby motor you will get ~180° sweep. I know this because the wife's Mini has it... ![]() |
Author: | cush [ Wed May 28, 2008 11:32 pm ] |
Morris 1100 wrote: Just take the left one off.
or wait for it to fall off, like in my case.. ![]() |
Author: | Gadgets mini [ Thu May 29, 2008 6:10 am ] |
cush wrote: Morris 1100 wrote: Just take the left one off. or wait for it to fall off, like in my case.. ![]() think of the savings Cush ![]() |
Author: | Kennomini [ Thu May 29, 2008 5:39 pm ] |
cush wrote: Morris 1100 wrote: Just take the left one off. or wait for it to fall off, like in my case.. ![]() Yeah I had that custom mod for a while aswell ![]() |
Author: | Morris 1100 [ Thu May 29, 2008 5:51 pm ] |
The best modification for the wipers on a Mini is to pull them apart and clean off the 40 year old grease and apply fresh stuff. |
Author: | cush [ Thu May 29, 2008 6:20 pm ] |
Gadgets mini wrote: cush wrote: Morris 1100 wrote: Just take the left one off. or wait for it to fall off, like in my case.. ![]() think of the savings Cush ![]() i would've been ok and bhuddist about it, if it was the passenger wiper... ![]() |
Author: | clubmn [ Thu May 29, 2008 6:23 pm ] |
Post subject: | mm1275 |
drmini in aust wrote: If you use early wheelboxes with a Clubby motor you will get ~180° sweep. I know this because the wife's Mini has it...
![]() Do u have a picture? |
Author: | drmini in aust [ Thu May 29, 2008 8:08 pm ] |
Post subject: | Re: mm1275 |
clubmn wrote: drmini in aust wrote: If you use early wheelboxes with a Clubby motor you will get ~180° sweep. I know this because the wife's Mini has it... ![]() Do u have a picture? Nothing to see, it is a 67 body which has the stock RH park wiper setup, but the PO fitted a clubby 2 speed motor. ![]() One day I'll put a square motor back on it... ![]() |
Author: | clubmn [ Fri May 30, 2008 6:56 am ] |
I get cha, for some reason I thought u moved the wiper in the middle of the car, But what your saying is you put a late model wiper motor that parks on the oppisite side, and it moves 180degres? |
Author: | Blokeinamoke [ Fri May 30, 2008 7:30 am ] |
Citroen Ax wiper motor centrally mounted |
Author: | drmini in aust [ Fri May 30, 2008 7:33 am ] |
clubmn wrote: I get cha, for some reason I thought u moved the wiper in the middle of the car, But what your saying is you put a late model wiper motor that parks on the oppisite side, and it moves 180degres?
yes. Mine doesn't auto park though as the PO mucked the wiring up. It's self parking, I park it myself. ![]() |
