It is currently Sat Jul 26, 2025 11:20 am
PostPosted: Sat May 17, 2008 9:08 pm
I rebore my engine in1362 with new piston from minisport.
does someone have an idea of the cr I will have with these pistons and a 21.4 cc cylinder head?
regards
www.moroccominiraid.blogspot.com
PostPosted: Sat May 17, 2008 9:11 pm
You will need to physically "Volumetriclly measure" it all to know for sure
PostPosted: Sat May 17, 2008 9:21 pm
these pistons are hypatec:
I have nothing to measure. the only thing I know is:
dish: 8cc
cylinder head gasket: 2.8cc
piston: 73.00mm
cylinder head volume: 21.4cc
I suppose other persons have the same spec. I send an email to andrew, but no answer...
PostPosted: Sat May 17, 2008 9:29 pm
as said,,, to do the job properly you will need to have someone volumetrically measure it all ,,, anyone who suggests otherwise is only guessing, simple as that
& burette is what`s needed & also someone who is used to using one doing CC measurements on engines,,, "SOME" engine reco shops have them,,, what`s quite surprising is that "ALL" engine reco places don`t.
& the head gasket will more than likely end up as 3.5cc volume
PostPosted: Sun May 18, 2008 11:27 am
Hi mate,
have you thought about using these pistons? You pay a little more, but you get a much better piston and ring set
http://www.ausmini.com/forums/viewtopic.php?t=41882
Chris
PostPosted: Mon May 19, 2008 5:10 pm
the material I have bought is good one, my question is just about the cr.
that's all
PostPosted: Sun May 25, 2008 9:03 am
10.5 to one cr
