Twin HIF44 Manifold https://ausmini.com/forums/viewtopic.php?f=5&t=41856 |
Page 1 of 2 |
Author: | spraycanmansam [ Fri May 09, 2008 7:42 pm ] |
Post subject: | Twin HIF44 Manifold |
Do people think there's enough meat in this manifold to port it out to 1.75" to run my twin HIF44's? http://www.minisport.com.au/prod482.htm ![]() I know Calver makes steel manifolds for them, but I think this looks more period ![]() |
Author: | gafmo [ Fri May 09, 2008 7:57 pm ] |
who cares for period when your talking twin HIF44's ![]() |
Author: | spraycanmansam [ Fri May 09, 2008 7:58 pm ] |
They'll look period from above! ![]() ![]() |
Author: | DOZ [ Fri May 09, 2008 8:04 pm ] |
spraycanmansam wrote: They'll look period from above!
![]() ![]() Above what? the bonnet! |
Author: | spraycanmansam [ Fri May 09, 2008 8:09 pm ] |
Ok, maybe I should explain, I'm going for the modernised old school idea. I'm still using SU's, just better more advanced ones.. electronic ignition, and so on. I don't want to take away the old school feel of the car ![]() |
Author: | Morris 1100 [ Fri May 09, 2008 8:13 pm ] |
spraycanmansam wrote: Ok, maybe I should explain, I'm going for the modernised old school idea. I'm still using SU's, just better more advanced ones.. electronic ignition, and so on. I don't want to take away the old school feel of the car Better and more advanced? ![]() ![]() ![]() |
Author: | spraycanmansam [ Fri May 09, 2008 8:15 pm ] |
Morris 1100 wrote: spraycanmansam wrote: Ok, maybe I should explain, I'm going for the modernised old school idea. I'm still using SU's, just better more advanced ones.. electronic ignition, and so on. I don't want to take away the old school feel of the car Better and more advanced? ![]() ![]() ![]() Doesn't that go for all modern cars these-days, more 'advanced' but more stuff to go wrong ![]() |
Author: | gafmo [ Fri May 09, 2008 8:17 pm ] |
Hay nothing wrong with HIF44 if you ensure everything id checked before installing just like a normal SU ![]() |
Author: | Morris 1100 [ Fri May 09, 2008 8:21 pm ] |
I have the same manifold as yours and I plan on fitting two HS6s to it. I have a very good reason for doing this. I only have 1 x HIF44. I have 3 x HS6. ![]() |
Author: | Morris 1100 [ Fri May 09, 2008 8:27 pm ] |
gafmo wrote: Hay nothing wrong with HIF44 if you ensure everything id checked before installing just like a normal SU It might be Ok when you fit it but after a couple of months when it needs new O-rings again.... ![]() ![]() |
Author: | spraycanmansam [ Fri May 09, 2008 8:30 pm ] |
Morris 1100 wrote: I have the same manifold as yours and I plan on fitting two HS6s to it.
I have a very good reason for doing this. I only have 1 x HIF44. I have 3 x HS6. ![]() What size motor? I'm going to run these on the Morrie |
Author: | gafmo [ Fri May 09, 2008 8:31 pm ] |
sorry 4 years and never had a problem ![]() I bet you have Jinsexed me now ![]() |
Author: | Asphalt [ Fri May 09, 2008 8:48 pm ] |
HIF kicks ass! ![]() Had continuoing (carn't spel too ![]() The biggest issue on a HS is the linear returning spring which gives a constant load on ONE point of the shaft's bearing. HIF has spiral springs which cures this problem to a great extent. I could imagine the seal leaking again and again if the throttle shaft is worn (which can of course happen to a HIF44!) and damages the seals due to too much play... Anyways: what Mini engine needs twin 1.75" carbs...? ![]() |
Author: | Minimad [ Fri May 09, 2008 9:25 pm ] |
Asphalt wrote: Anyways: what Mini engine needs twin 1.75" carbs...?
![]() Mine ![]() I have just done one of these manifolds for 1.75" carbs. Plenty of meat in them. Need to drill and tap the extra studs to hold the carbs on though Minimad |
Author: | spraycanmansam [ Fri May 09, 2008 9:29 pm ] |
Minimad wrote: Asphalt wrote: Anyways: what Mini engine needs twin 1.75" carbs...? ![]() Mine ![]() I have just done one of these manifolds for 1.75" carbs. Plenty of meat in them. Need to drill and tap the extra studs to hold the carbs on though Minimad Thank you, all these posts and an answer! ![]() ![]() Do you have any pics? I figure that a Weber has 45mm throats and the engine never sees them both, so why not twin 44.5mm? ![]() ![]() |
