'A' auto box vs. 'A+' auto box https://ausmini.com/forums/viewtopic.php?f=5&t=41794 |
Author: | spraycanmansam [ Wed May 07, 2008 6:57 pm ] |
Post subject: | 'A' auto box vs. 'A+' auto box |
Any differences? I know that the later boxes had a park position, but what about things like strength? Will a later A+ auto fit an A series auto block? Cheers, Sam |
Author: | bnicho [ Thu May 08, 2008 11:28 am ] |
Not all A+ Autos had Park (PRN123D) - only 89ish onwards. Earlier A+ just had RN123D. A series had RN1234D. On the A+ boxes you can't manually hold 4th, you can on the A boxes. The ratios and valve bodies differ too. In theory an A+ Autobox should bolt to an A Auto engine with the appropriate drop gears and maybe torque converter. But I haven't tried it, so I don't know for sure. Having driven both an A and A+, the A+ is smoother and seems tougher. The final drive is taller which gives lower crusing speed at the expense of acceleration. Cheers, |
