It is currently Sat Jul 19, 2025 10:23 pm
 Post subject: Mini Remote Gearbox
PostPosted: Sat Apr 26, 2008 4:36 pm
Its proberly on here somewhere.....but I cannot find........I hav a 22g1128 remote gearbox off a 998 aussie assembled mini.....I am wanting to know if i can put a 1300 mini engine on the box........My current mini has the same box #,......I hav heard that there is a difference in the casting of some boxes small engine to large engine.... is there a difference in these???? they are both made by mowog..... I dunno wat else to say Please help?
Many thanks
Damon
61 van
63 countryman
63 saloon
67 auto
73 auto clubman
75 1000cc clubman
77 sccr 998 clubman
NZ 79 1275gt clubman estate
79 LE
80 meanee
Racecar
Fiat 500
PostPosted: Sat Apr 26, 2008 4:50 pm
a 1275/1300 bolts straight on there. A series or A+, no difference.
I used one under my 1412 stroker when I ran it on the engine dyno, it was a stock Mini-K case. Also these were used here for Mk2 1275S and early 1098 Clubby.
It's the 3 synchro boxes that often need fettling (sometimes major) for a 1275 to fit. :wink:
 Post subject: Re: Mini Remote Gearbox
PostPosted: Sat Apr 26, 2008 6:23 pm
Damon
can I be super pedantic and say that it would have been a 1098 originally?? :lol:
PostPosted: Sat Apr 26, 2008 8:42 pm
I agree, we never put 998 motors onto this box. :wink:
By the time the Clubby here got the UK `99H' 998 motors we were using rodchange boxes.
PostPosted: Sat Apr 26, 2008 9:17 pm
Thanks.... the engine its bolted to has a 99#@^& tag on it. Could had been changed at some time....lots of gasket sealent used. I guess with the slightly longer stroke of the 1100 it has the clearence Im looking for........If the crank dont turn when I put it on there will be trouble.......hehehe
61 van
63 countryman
63 saloon
67 auto
73 auto clubman
75 1000cc clubman
77 sccr 998 clubman
79 LE
80 meanee
Racecar
Fiat 500
PostPosted: Sun Apr 27, 2008 12:32 am
Brik nuts,,, just don`t forget that if you`re going to put a 1275 or bigger engine onto it, then make sure the gearbox is actually in good nick first ... & also you will need the 1275 type primary gear to suit it too
