It is currently Sat Jul 19, 2025 3:54 pm
PostPosted: Wed May 07, 2008 6:57 pm
Forum Graffiti
Any differences?
I know that the later boxes had a park position, but what about things like strength? Will a later A+ auto fit an A series auto block?
Sam
PostPosted: Thu May 08, 2008 11:28 am
Not all A+ Autos had Park (PRN123D) - only 89ish onwards. Earlier A+ just had RN123D. A series had RN1234D. On the A+ boxes you can't manually hold 4th, you can on the A boxes. The ratios and valve bodies differ too.
In theory an A+ Autobox should bolt to an A Auto engine with the appropriate drop gears and maybe torque converter. But I haven't tried it, so I don't know for sure.
Having driven both an A and A+, the A+ is smoother and seems tougher. The final drive is taller which gives lower crusing speed at the expense of acceleration.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
