slinkey inc wrote:
(slightly off topic) - Just recently I bought a pair of HIF44Es The E stands for electronic. The bloke who sold them to me told me they were injection carbies, like they weren't carbies anymore. I knew that was totally untrue when I pulled them off the shelf and saw a set of needles in them. Basically I got a set of HIF44s cheap. They can be converted to manual choke and all, but it would a shame to waste the intricate choke and stepper motor system.
That would be similar to what is on my Austin Montego. The stepper motor runs the choke via computer depending on air temp, motor temp and other things. The computer is dead on mine! So I pulled apart the stepper motor and use the choke manually. The computer also runs a fuel shut off on over-run so that when you lift the foot is does not use any fuel.
The downside was the Lucas computer.
Alas I lack the Lucas computer. I bought them more as an oddity rather than anything else and upon researching I found that Burlen make a manual choke kit (I think I'll make it myself though, it looks simple) and the carbie can be used as any other HIF44. I now have 2 spare ball bearing suction chambers (for lack of a better term) and lots of spare bits, or 2 complet HIF44s.
The anti-run-off cut off system is the best feature. I don't think it is possible to make work, well not easily anyway but definitely a good idea.
Maybe in my 2nd year of uni, after completing some electronic engineering subjects I
might be able to do something with them....or not.
1977 Leyland Mini LS - Project LS-T
