Ho to... https://ausmini.com/forums/viewtopic.php?f=5&t=38982 |
Author: | leyland brother [ Sun Dec 23, 2007 4:58 pm ] |
Post subject: | Ho to... |
I need to remove my speedo cable drive gear from the bottom of the motor. I've managed to remove the 7/16" bolt that holds down the outer casing via a metal fork, but for the life of me cannot get the drive gear assembly out. I was told it should have popped out with the metal casing but it wont. I tried with long nose pliers to lever it off against the harmonic balancer but no go. Any suggestions please??? |
Author: | Mick [ Sun Dec 23, 2007 5:02 pm ] |
Keep at it, it's only held down by one bolt so will eventually come away. Might be a trick to try and twist it a little before trying to hard to lift it off. It might need to have the gasket cracked before it will want to come out. Good luck with that one.. |
Author: | TheMiniMan [ Sun Dec 23, 2007 5:18 pm ] |
Nah, i bet he has the retainer out, & now the metal guid sleeve is stuck, they jam like their welded sometimes, steel & alloy just love bonding themselves together you need some good penetrating fluid & some decent grunt & then maybe the nylon gear will break off the bottom of the steel speedo drive tube & leave you in the sh!t & you`ll have to take the whole end casing off the box to get it out ![]() fun job hey???? ![]() good luck ![]() |
Author: | leyland brother [ Sun Dec 23, 2007 5:32 pm ] |
Lets not forget about Murphy's Law... |
Author: | gafmo [ Sun Dec 23, 2007 6:20 pm ] |
Its the way you hold your tounge..when you wiggle it. Degress the buggery out of it..them WD40 and give it a good wiggle and pull.. |
