It is currently Wed Jul 09, 2025 8:39 am
 Post subject: Ho to...
PostPosted: Sun Dec 23, 2007 4:58 pm
I need to remove my speedo cable drive gear from the bottom of the motor.
I've managed to remove the 7/16" bolt that holds down the outer casing via a metal fork, but for the life of me cannot get the drive gear assembly out. I was told it should have popped out with the metal casing but it wont. I tried with long nose pliers to lever it off against the harmonic balancer but no go.
Any suggestions please???
Santo
"The Lone Ranger"
HI-HO Silver......AWAAAAAY!
PostPosted: Sun Dec 23, 2007 5:02 pm
Keep at it, it's only held down by one bolt so will eventually come away.
Might be a trick to try and twist it a little before trying to hard to lift it off. It might need to have the gasket cracked before it will want to come out.
Good luck with that one..
PostPosted: Sun Dec 23, 2007 5:18 pm
Nah, i bet he has the retainer out, & now the metal guid sleeve is stuck, they jam like their welded sometimes, steel & alloy just love bonding themselves together
you need some good penetrating fluid & some decent grunt & then maybe the nylon gear will break off the bottom of the steel speedo drive tube & leave you in the sh!t & you`ll have to take the whole end casing off the box to get it out
fun job hey???? :-)
good luck
PostPosted: Sun Dec 23, 2007 5:32 pm
Lets not forget about Murphy's Law...
Santo
"The Lone Ranger"
PostPosted: Sun Dec 23, 2007 6:20 pm
Its the way you hold your tounge..when you wiggle it.
Degress the buggery out of it..them WD40 and give it a good wiggle and pull..
Users browsing this forum: No registered users and 26 guests
