It is currently Tue Jul 08, 2025 7:57 pm
 Post subject: How to tell
PostPosted: Sun Dec 16, 2007 11:09 pm
Hi all,
My mini K has a 1275 fitted at the moment, and im looking around to find parts etc for the rebuild, and I'm looking at the gearbox too...
Now because i am a bit new to this, how do I tell what type of gearbox i have? Remote? etc?
It is a 4 speed, with reverse over on the right and down... Is it the standard miniK box, or the box that came with the 1275?
Many thanks
 Post subject: Re: How to tell
PostPosted: Sun Dec 16, 2007 11:20 pm
Forum Graffiti
Timinik wrote:
Hi all,
It is a 4 speed, with reverse over on the left and down... Is it the standard miniK box, or the box that came with the 1275?
Many thanks
Don't you mean over on the right and down? :?
Mini K's came with a remote gearbox. Have a look under the car and if there's a big kind of long 'box' casing thing going from where the gearbox is to the below where the gear lever is, it's remote. If there's a small 'box' below where the gear lever is and rods coming out of it to the gearbox, its a rod box :)
In this pic you can just see the little box from my rod change i was talking about behind the block. You'll know if it is or isn't this when you have a look under :wink:
Sorry for the explanations, hope you get the idea! :P
PostPosted: Mon Dec 17, 2007 12:08 am
Forum Graffiti
And heres the long 'box' thing I was talking about.
The end on the left goes to the gearbox and the right to the stick :)
PostPosted: Mon Dec 17, 2007 6:03 am
If you have to lift the lever to get reverse, it's a rodchange. If you just knock it across hard, it's a remote shift. :wink:
PostPosted: Mon Dec 17, 2007 5:04 pm
And it goes "clunk" when you knock it across. A well trained ear can hear the difference between a rod change and a remote change from outside the car!
PostPosted: Mon Dec 17, 2007 8:14 pm
get a look at the casting number on the front of the gearbox, near & behind the oil filter area & then post it here to confirm exactly what box it is
PostPosted: Thu Dec 20, 2007 9:44 am
Resident Test Pilot
along with the well trained ear you would have to have arms like an orangutan to be able to do this !
