https://ausmini.com/forums/
SU question
https://ausmini.com/forums/viewtopic.php?f=5&t=38439
Author:  wyan [ Tue Dec 04, 2007 7:57 pm ]
Post subject:  SU question
Just a quick question, if su's work under vacume will they still work normally if set-up as a blow-through forced induction? I have seen suck though set-ups, but can they work with an intercooler, or will the intercooler mess about with the fuel/ air mixture or anything?
Thanks!
Author:  Mick [ Tue Dec 04, 2007 8:18 pm ]
There are blow through set ups used from the factory on Metro Turbo engines. These can be found and no further mods are required to use them.
I think normal SU's can be modified to run with boost at a cost.
Author:  wyan [ Tue Dec 04, 2007 8:27 pm ]
yeah Im in the process of getting one of a metro turbo from the UK. Is it the HIF6 or the HIF44 off a metro turbo? and do you know if n/a metros used the same carb as the turbo ones?
Author:  TheMiniMan [ Tue Dec 04, 2007 8:52 pm ]
The factory turbo specific SUs had sealed shafts, balanced breathing to the float bowl & linkages were on the opposite side of the carbs than the "usual" possition i believe (that may not allways be the case tho as people can "play" with that part of it quite easilly & change things around to suit "their own" application)
& yes, you can intercool it all before/prior the carb
Author:  spraycanmansam [ Tue Dec 04, 2007 9:16 pm ]
IIRC the turbo Metro's used a boost modified HIF44.
Intercooling a blow-thru setup is fine, but NOT a suck-thru setup. The fuel pools in the intercooler and you basically end up with a bomb waiting to explode ( backfire = dead :evil: ). On that note I have seen it done :shock: You wouldn't catch me near it... :?
Author:  Moke'n'Andy [ Wed Dec 05, 2007 5:09 am ]
I have just set a blow through on a HIF44 metro turbo.
http://moke.com.au/Forum/index.php?topic=1858.0
This is a link to the moke forum with some of the latest pictures.
Author:  wyan [ Wed Dec 05, 2007 5:00 pm ]
yeah thats what I thought would happen with a suck thru-intercooled set-up, Im going for my origianl plan of a blow-through intercooled, which is good as I have all the parts already (besides my carb..) so they wont end up as dust collectors haha.
Author:  Asphalt [ Tue Dec 11, 2007 4:27 am ]
Other suck-through issue is the vacuum in the turbo at part-throttle.
If it has no special seals, it`l draw the oil out of the bearings.
