https://ausmini.com/forums/
Weber Air filter Mod Hiclone Idea
https://ausmini.com/forums/viewtopic.php?f=5&t=37993
Page 1 of 2
Author:  R(a)ph [ Tue Nov 20, 2007 8:00 pm ]
Post subject:  Weber Air filter Mod Hiclone Idea
Well im a n00b with engines! But skilled in the arts of exciting ideas.
I have a Weber 40DCOE on my 1100cc and i was wondering if it is possible to run a pipe air intake with a Hiclone filter that uses the windforce through the front grill. basically fit a hiclone to a Weber. I would design a mold that is flush with the old filter shape and change the direction towards the direct airflow. Constructive criticism welcome i want to learn.
Author:  Mick [ Tue Nov 20, 2007 8:08 pm ]
I remember the Australian online performance magazine (who's name escapes me) tested Hi-Clone in a number of different car applications.
They found that the (very slight) benefits of the hiclone were there for some vehicles, and not for others. Rifling the airflow has benefits, but if it is upset by something in the path then it is all for naught.
What you propose has a long unimpeded tube with a hiclone at the front, so there may be benefits, but I don't think that it might be worth it really. How many production vehicles (where performance and noise reduction is really important) have these fitted?
Saying that, nothing wrong with a cold air intake if you like...
Author:  drmini in aust [ Tue Nov 20, 2007 8:09 pm ]
That might work with fuel injection but with a carb it just buggers up the carb's mixture control.
Usually if you want cool air to a Weber you run a hose from front grille up near to, but not attached to the carb.
Author:  Morris 1100 [ Tue Nov 20, 2007 8:12 pm ]
Rule 1. Don't listen to common sense, just do it. :wink:
Author:  Kennomini [ Tue Nov 20, 2007 8:34 pm ]
So this IS a good idea then :lol:
Author:  R(a)ph [ Tue Nov 20, 2007 8:34 pm ]
Well i think i may just go the pipe intake idea and pump out cold air in front of the filter. Or maybe a small scoop. Cheers anyway oneday when i can risk a possibly expensive idea without certain results i will.
Im in a funny situation actually. Im saving to go to europe with my girlfriend and restoring my mini. so i work extra for mini and the rest for europe. sadly people dont understand why i dont just wait untill i get back. But i tried saying no to my addiction, alas i find too many "Perfectly understandable"justifications..
You can turn your back on a person, but you can never turn your back on a Mini
Im in a very good job and earn 600+ weekly without fail i have to save 6000 to leave mid nxt year and pay no rent and no bills. So just make me feel somewhat less guilty....hehe :P
Author:  Mick [ Tue Nov 20, 2007 8:36 pm ]
You can sleep in a mini, but you can't drive a house.... 8)
Author:  Morris 1100 [ Tue Nov 20, 2007 8:40 pm ]
What is the temperature of the air coming in the grille?
What is the air pressure of the air coming in the grille?
What is the temperature of the air at the carby?
What is the air pressure of the air at the carby?
Have you ever heard of carby ice?
What makes you think that the air coming into the carby can be improved? 8)
Author:  R(a)ph [ Tue Nov 20, 2007 8:47 pm ]
Well didnt really think of that. Within a week the filter gets dirty and filled with petrol, my engine runs rich and i loose power. I want more power and i thought increase airspeed would improve combustion.
I want more power without supercharging or turbo ( P lisence)
Author:  Morris 1100 [ Tue Nov 20, 2007 8:50 pm ]
If you want to increase airflow you open the throttle. 8)
If your air filter fills with petrol and dirt within a week you have a problem.
Author:  R(a)ph [ Tue Nov 20, 2007 8:55 pm ]
My mechanic says its running to rich but he refuses to attemp tuning, apparently one needs and enormous amount of parts to get the best economy performance ratio
Author:  pristic [ Tue Nov 20, 2007 9:37 pm ]
Find a new mechanic!
Dont run an intake pipe ... useless on a mini really. The air temp at the carb mouth and right in front of the grille is the same.
If you have the filter clogging up with dirt every week, you probably have a very poor flowing air filter. There are probably better filters that will help...
Dont over oil the filter!!! It dont work so good that way.
More power is not as simple as more air... find a good mechanic that will tune it for you properly. That might make more power if your tune is off at the moment.
How do you know its running rich?
Peter.
Author:  R(a)ph [ Wed Nov 21, 2007 10:14 am ]
Well firstly the petrol smell gets stronger the filter gets soaked in petrol and less air gets in the mix so i have worse acceleration.
Plus my exhaust mechanic thinks its rich.I may ask him he has a Torana V8 with 3Carbies he may be tuning savvy
Author:  Lillee [ Wed Nov 21, 2007 10:18 am ]
You will get more power from a set of stub stacks or ramtubes on the weber and a longer intake manifold. These are proven power gain modifications. Cold air raming etc is a theory at best...
Author:  bnicho [ Wed Nov 21, 2007 11:32 am ]
Hi,
As others have said sort out the basic running problems first, then worry about bolt-on performance parts.
Vizard tried a similar idea and found there was a torque benefit in a long intake pipe with a K & N filter down behind the grille. See "Tuning BL's A Series Engine" for details. But Vizard wasn't intending to "ram in" air, just suck in cooler air.
