It is currently Tue Jul 08, 2025 7:56 pm
PostPosted: Fri Nov 09, 2007 7:30 pm
Hi guys,
I have these new guides to fit in my head. They appear bullet nosed but I have no reference.
If these are not bullet nosed I was going to clamp them (gently) in my pedestal drill and touch them with a file.
Heres a photoImage
Thanks everyones
I forgot to mention, I am only going to do the inlets. I have pulled a few heads down and the ex guides have all been knackered. Plus it might help draw some of the heat away from the valve itself.....maybe?
blokeinamoke wrote:
PostPosted: Fri Nov 09, 2007 8:17 pm
Yes those are bullet nosed 1275 guides, you will find they are a few mm longer than the old 1098 ones you removed.
As you are using 1275 valves now I'd not shorten them, just fit them a bit higher in the head. I make them 16mm above in a 202 head with 1275 valves in.
PostPosted: Fri Nov 09, 2007 9:58 pm
OKie DOkie
Less work for me...yay
We had this valve discussion in PM doc,
we concluded 16-17mm above would be best.
thanks Kev
blokeinamoke wrote:
