It is currently Tue Jul 08, 2025 7:59 pm
PostPosted: Thu Nov 08, 2007 3:07 pm
Hi Guys,
Im redoing my engine, and was looking at the Keith Dood Rockers 1.5 but have heard they are having problems. Anyone using the Roller Tip Rocker Assemblies - Mini Sport - 1.5:1 - Red, and if so what are they like. My car will be a 1380 with a 266 Kent Cam, Twin 1.5 SU Carbs.
PostPosted: Thu Nov 08, 2007 3:39 pm
Would that be Minisport in South Australia, or Minisport UK.
Because they are different I believe. The SA Minisport sells Minispares products.
No idea about the rocker's though....
PostPosted: Thu Nov 08, 2007 4:35 pm
the Minisport UK 1.5:1 rockers are red, i know.
only complain i have with them is they use a bush and not a spring between the rockers and are a bit noisy.
i have never had any problems with the Dodd rockers but have seen Minisport ones broken (but i don't know if they were fitted correctly)
Rover 214 atm ....
PostPosted: Thu Nov 08, 2007 8:06 pm
I saw a set of Minisport red 1.5 roller tip ones get flats on many of the rollers in under 10,000 km. It was years ago though, new ones may be better. :wink:
re the 1.5 Minispares forged ones, I've done about 40,000 miles on a set and they are fine. God knows where they are made now though- India? China? :? It takes MSC forever to get stock when they run out.
PostPosted: Fri Nov 09, 2007 1:12 pm
I bought a set of the 1.5s from MiniSport UK about a month ago. Not on the car yet so can't say anything about performance or how long they will last.
I can comment however on the poor service from Minisport. I paid top dollar/pound to get them here in 6 to 7 seven days, took more like 6 to 7 weeks. Despite me emailing them constantly, they didn't like to reply to my correspondence.
Previous to this purchase I had bought heaps from them, now I dunno if I would again. :(
PostPosted: Fri Nov 09, 2007 10:54 pm
Have not heard or read about any problems with Keith Dodd 1.5's.
The Doc gave me some advice about replacing rocker bushes and shaft on this set-up...but I put that down to normal wear and "tear".
 Post subject: I heard...
PostPosted: Sat Nov 10, 2007 11:20 am
That Minispares may have changed the supplier, and some have been 1.6 and even 1.7 from the factory, I might go with a set from MED in the UK, they seem to have a good history??
 Post subject: Re: I heard...
PostPosted: Mon Nov 12, 2007 11:33 pm
MED rockers are outstanding from all reports. Haven't used them yet myself though.
They are the ones I would get next time i buy a set, no questions asked, and Steve Whitton (MED) is a great guy by email!
M
PostPosted: Tue Nov 13, 2007 12:59 am
some days ago i had Swiftune rockers on my bench. looked very nice
http://www.swiftune.co.uk/
Rover 214 atm ....
PostPosted: Tue Nov 13, 2007 7:40 pm
I like my converted Toyota Corolla ones, 1.46:1- here they are with a Cooper S set.
PostPosted: Tue Nov 13, 2007 10:03 pm
Doc,,,, i`ve allways said that you have a good shaft :-)
& with regards to "roller" rockers,,, that`s why my own design have extreamly hard actual roller bearings (2 or them on each tip) as the roller on the tip of the rocker & not just a pin through a piece of steel roller
