It is currently Tue Jul 08, 2025 12:27 am
PostPosted: Tue Oct 30, 2007 8:16 pm
Hey everyone
I did a search, but no luck.
I want to make my front subframe lighter.
Weight from the engine aside, how much can you take out of the front subframe before its going to brake? (drilling holes etc)
I have seen pics of people drilling heaps of holes in there subframes, anyone on here done it?
thanks
PostPosted: Tue Oct 30, 2007 10:03 pm
I have seen first hand a couple of racers with "swiss cheesed" front subframes. Doubt that it saved more than 2 kg although I have no confirmed figures to back that up.
From calculations, each 50mm hole in 3mm plate (are subframe webs 3mm?) will only save 15g. That's a lot of holes to make up a kg. The idea is to reduce mass from EVERYTHING. You included.
Peter Manton (look him up young ones) was a very successful racer with this strategy. EVERY item was lightened, even to the extent of drilling into the top of every bolt head to remove a gram of extra mass. Of course things light BMC racing alloy doors helped a lot too...
PostPosted: Tue Oct 30, 2007 10:06 pm
Oh, and see my sig. Do a search on Lotus & Mr Chapman.
They had/have the right idea (except with the Europa).
PostPosted: Wed Oct 31, 2007 8:59 pm
Jaan Fox took 150kg out of his silver slab, but that included taking 2 inches out of the roof and bodyline
I think I saw a Europa in Albury last week, either a Europa, or an odd looking replica
PostPosted: Thu Nov 01, 2007 9:25 am
hmmm....I always thought it was "Simplify and add lightness"
PostPosted: Thu Nov 01, 2007 12:49 pm
Use your current one as a template to make one out of carbon fibre!! Will look trick too.
Probably be able to sell a few on here to cover the costs..... 8) :D
68 Mini
70 Moke
PostPosted: Thu Nov 01, 2007 3:22 pm
Have a look at the Z-cars front subframes. Given the freight would be a killer, but might give you ideas.
http://h8bmwmini.blogspot.com/2007/04/z-cars-series-subframe.html
2008 Prado GXL
