https://ausmini.com/forums/
Front subframe - ways to make it a little lighter?
https://ausmini.com/forums/viewtopic.php?f=5&t=37248
Author:  -=MiniMafia=- [ Tue Oct 30, 2007 8:16 pm ]
Post subject:  Front subframe - ways to make it a little lighter?
Hey everyone
I did a search, but no luck.
I want to make my front subframe lighter.
Weight from the engine aside, how much can you take out of the front subframe before its going to brake? (drilling holes etc)
I have seen pics of people drilling heaps of holes in there subframes, anyone on here done it?
thanks
Author:  awdmoke [ Tue Oct 30, 2007 10:03 pm ]
I have seen first hand a couple of racers with "swiss cheesed" front subframes. Doubt that it saved more than 2 kg although I have no confirmed figures to back that up.
From calculations, each 50mm hole in 3mm plate (are subframe webs 3mm?) will only save 15g. That's a lot of holes to make up a kg. The idea is to reduce mass from EVERYTHING. You included.
Peter Manton (look him up young ones) was a very successful racer with this strategy. EVERY item was lightened, even to the extent of drilling into the top of every bolt head to remove a gram of extra mass. Of course things light BMC racing alloy doors helped a lot too...
Author:  awdmoke [ Tue Oct 30, 2007 10:06 pm ]
Oh, and see my sig. Do a search on Lotus & Mr Chapman.
They had/have the right idea (except with the Europa).
Author:  simon k [ Wed Oct 31, 2007 8:59 pm ]
Jaan Fox took 150kg out of his silver slab, but that included taking 2 inches out of the roof and bodyline
I think I saw a Europa in Albury last week, either a Europa, or an odd looking replica
Author:  smac [ Thu Nov 01, 2007 9:25 am ]
hmmm....I always thought it was "Simplify and add lightness"
Author:  Smarty [ Thu Nov 01, 2007 12:49 pm ]
Use your current one as a template to make one out of carbon fibre!! Will look trick too.
Probably be able to sell a few on here to cover the costs..... 8) :D
Author:  Fat Boy Dave [ Thu Nov 01, 2007 3:22 pm ]
Have a look at the Z-cars front subframes. Given the freight would be a killer, but might give you ideas.
http://h8bmwmini.blogspot.com/2007/04/z-cars-series-subframe.html
