https://ausmini.com/forums/
overhead cams?
https://ausmini.com/forums/viewtopic.php?f=5&t=37242
Author:  cookie720 [ Tue Oct 30, 2007 5:29 pm ]
Post subject:  overhead cams?
How does this actually work in minis, what happens to the old cam? Is it still an A-series engine block? Thanks
Author:  TheMiniMan [ Tue Oct 30, 2007 6:07 pm ]
yes, the old mini cam shaft stays there as it still drives the oil pump & distributor (if you use one)
Yes the original A series block is used & just some mods needed to it so the cyl head fits on,,, then add all the drive gear for the cams etc & Bob`s your Aunty :-)
Turbo Inject it & you have more pull than a bunch of school boys :-)
