It is currently Wed Jul 09, 2025 3:01 am
 Post subject: overhead cams?
PostPosted: Tue Oct 30, 2007 5:29 pm
How does this actually work in minis, what happens to the old cam? Is it still an A-series engine block? Thanks
PostPosted: Tue Oct 30, 2007 6:07 pm
yes, the old mini cam shaft stays there as it still drives the oil pump & distributor (if you use one)
Yes the original A series block is used & just some mods needed to it so the cyl head fits on,,, then add all the drive gear for the cams etc & Bob`s your Aunty :-)
Turbo Inject it & you have more pull than a bunch of school boys :-)
