Keith Dodd 1.5 Forged Rockers. https://ausmini.com/forums/viewtopic.php?f=5&t=37107 |
Author: | LS1380 [ Thu Oct 25, 2007 9:53 pm ] |
Post subject: | Keith Dodd 1.5 Forged Rockers. |
Not the best pic- ![]() Question: On this set-up,at the exhaust rockers on the end,is there suppose to be a coil washer?Or does this set-up run a flat washer only? |
Author: | drmini in aust [ Thu Oct 25, 2007 10:10 pm ] |
Pretty sure it's flat washer only. Like a Cooper S. I'll check mine tomorrow if you like. ![]() |
Author: | LS1380 [ Thu Oct 25, 2007 10:25 pm ] |
Thanks-Much appreciated. This set-up has only flat washers-no coil washer and very noisy at number No1.(clearance checked and double checked). |
Author: | drmini in aust [ Thu Oct 25, 2007 10:40 pm ] |
If there's room for a coil washer fit it, otherwise make a thicker washer to take up the slack. Are you sure it's not a worn bush.... |
Author: | LS1380 [ Thu Oct 25, 2007 10:47 pm ] |
drmini in aust wrote: If there's room for a coil washer fit it, otherwise make a thicker washer to take up the slack.
Are you sure it's not a worn bush.... Thanks-Thats next....it sounds like a hot EH 179 with hydraulic lifters ![]() |
Author: | drmini in aust [ Sun Oct 28, 2007 10:00 am ] |
OK I just checked mine- yes they DO have the coil spring each end, and a flat washer. You buy these Minispares forged rockers as a kit- all you get is the rockers, a HD shaft and 4 new posts. You make your own arrangements regarding using your old parts on assembly. I apparently had room for the coil springs. ![]() |
Author: | LS1380 [ Sun Oct 28, 2007 8:02 pm ] |
Thanks Kevin-I'm going to muck around with the coil spring,but I'm thinking bush as well. |
