Vic RWC required in inner west https://ausmini.com/forums/viewtopic.php?f=5&t=36400 |
Page 1 of 2 |
Author: | Fat Boy Dave [ Fri Oct 05, 2007 12:56 pm ] |
Post subject: | Vic RWC required in inner west |
Hi Guys, I need to get a VIC RWC on a Mini. Can someone please recommend someone in inner West of Melbourne. The car currently has NSW rego but in order to transfer it to VIC I need to get a RWC. ![]() I am likely to need at least: new windscreen fix oil leak ![]() at least 1 new CV fix wipers (appears to be mechanical not electrical) and this is without being checked out! Please no flaming unless you want ot PM me. ![]() I just basically want to get my car registered in VIC with a minimum of fuss before I do any mods, i.e. disc brakes, adjustable arms..... Thanks. |
Author: | sgc [ Fri Oct 05, 2007 1:00 pm ] |
Me too! Going to need a Vic RWC in the same area in a couple of weeks. Preferably without having to go through the wringer ![]() |
Author: | Fat Boy Dave [ Fri Oct 05, 2007 1:50 pm ] |
If I had a NSW address it would be a non issue. ![]() |
Author: | Ziegech [ Fri Oct 05, 2007 9:24 pm ] |
place called "Ravenhall" in westwood drive but they wont pick problems that need changing so id only recommend them if ur confident of the cars safety |
Author: | Davo111 [ Wed Oct 10, 2007 3:31 pm ] |
Post subject: | Roadworthy in West Subs, Vic |
I just had mine Roadworthied in Hoppers Crossing 3 weeks ago, to change from S.A. rego over to Vic Rego. Mechanic was thorough but I had to show them where everything was as they have limited knowledge of Minis, this can be helpful. If you want the address, P/M me and I will return it ![]() |
Author: | sgc [ Sun Oct 14, 2007 3:55 pm ] |
Post subject: | Re: Vic RWC required in inner west |
Fat Boy Dave wrote: I need to get a VIC RWC on a Mini.
So Dave, how'd you go? |
Author: | Fat Boy Dave [ Mon Oct 15, 2007 10:02 am ] |
Still procrastinating. ![]() |
Author: | sgc [ Mon Oct 15, 2007 10:31 am ] |
I am, car's not. Will be here in a coupla weeks. |
Author: | Davo111 [ Wed Oct 17, 2007 9:34 am ] |
Post subject: | R/W certificate |
Got the certificate with no problems, car is now registered in Vic, got the new WAO... plates. Let me know if you need any help or further info. Davo.....111...... |
Author: | sgc [ Tue Oct 30, 2007 7:34 pm ] |
Fat Boy Dave wrote: Still procrastinating.
![]() C'mon Dave, you done your RWC yet? I need to get mine now, maybe we can get two for the price of one? ![]() Anyone got any other suggestions for a Mini-friendly RWC'er in inner Melbourne? |
Author: | Fat Boy Dave [ Fri Nov 02, 2007 9:22 am ] |
When I finally get the right boss for my steering wheel I would be interested to see if we get a 2 for 1 deal. Somehow I think mine might be a bit more $ than yours to roadworthy though. But I'm ready. ![]() |
Author: | sgc [ Fri Nov 02, 2007 10:50 am ] |
Fat Boy Dave wrote: But I'm ready.
![]() I'll probably use Davo111's guy in Hoppers, hopefully next week some time. Gotta get the hydro pumped up a bit first so they can get it on the hoist (nothing to do with the height being 'illegal', nooooo) ![]() How's that suit? I'm sure they'd be happy to do two Mini's at the same time ![]() |
Author: | Fat Boy Dave [ Fri Nov 02, 2007 11:03 am ] |
Deal. I'll try and sort out steering wheel on the weekend. You don't have a spare boss do you? I ended up buying the wrong one, so need to organise a differnet one to fit steering wheel. |
Author: | sgc [ Fri Nov 02, 2007 11:04 am ] |
Fat Boy Dave wrote: You don't have a spare boss do you?
Nup, sorry ![]() [edit] Read your PMs ![]() |
Author: | sgc [ Thu Nov 08, 2007 10:02 am ] |
sgc wrote: I'll probably use Davo111's guy in Hoppers
What a mistake that was. I just got back, and I'm still angry. ![]() They tried picking things which were obviously fine (e.g. lights not working.. I call bullshit and show them). Brake lights don't work? Here, see this? Try doing it with the ignition on. They tried telling me there are spacers on the front which must be removed.. they're DRIVE FLANGES, you morons. Remove those 4 screws and the discs fall off. They complained the reversing lights didn't work. Uhh, guys, reversing lights came into the ADRs in '72, this is a '70.. $88 down the drain. They did pick some stupid small fiddly stuff like missing grommets, no hose clamp on the fuel filter input, etc.. which I'll fix, and after I 'set them straight' they've told me that they'll write the cert when I do the stupid stuff. Not happy, Jan ![]() ![]() |
